1978 - 1996 Big Bronco
Timing
Old May 9, 2005 | 10:02 PM
Gurahl's Avatar
Gurahl
Timing
Alright, I reset my base timing.
Am I supposed to disconnect the battery for 5 minutes now, or is this not necessary with this procedure?
Gurahl and Bronc'nstein
Old May 9, 2005 | 11:24 PM
greystreak92's Avatar
greystreak92
Its only necessary to disconnect the battery for a few minutes if you need to clear old stored codes that you have taken steps to fix the problems. A reset of the PCM by disconnecting the battery isn't necessary with a base timing reset. The "loss of SPOUT signal" code (Code 18 on most EEC engines) will clear itself once the signal is reinstated (SPOUT connector reinstalled).
Gurahl
Sep 3, 2013 09:19 AM
Gurahl
Apr 30, 2006 12:09 AM
Gurahl
Jul 17, 2005 07:55 AM
Gurahl
Mar 30, 2005 03:55 PM
Gurahl
Mar 24, 2005 09:41 AM
