Alternators keep dying
Old May 9, 2005 | 09:18 PM
No_BS's Avatar
No_BS
I need some serious help. I did a 3g alternator conversion on my '91 F-150 5.0 following these instructions. Now, 2 weeks and around 400 miles later, the thing is shot (and this is not the first time). The problem is, the shaft moves forward and back, causing internals to hit the case. I do not understand why this keeps happening. Is it the alternators, or is it me? I really would love to know. Any help will be appreciated, wether it's good or bad.
Old May 9, 2005 | 10:05 PM
Franklin2's Avatar
Franklin2
Sounds like you have a mechanical problem. So I would double check belt tension, and pulley alignment. If the alternator is not sitting perfectly square with the drive belt, it could put a side load on the alternator shaft.
Old May 11, 2005 | 01:31 AM
RomerB2's Avatar
RomerB2
I was thinking that you have your belts too tight. And as Franklin said, check pulley allignment.
Old May 12, 2005 | 04:25 PM
No_BS's Avatar
No_BS
I figured it out. Took the alternator to an alternator and starter shop only to find out there was absolutley nothing wrong with it. I came home, put it back in and drove it until the noise started again. Used a metal pipe to listen for sound, and sure enough it was not the alternator, but the tensioner. They are bolted directly together, so the sound seemed to be coming from the alt. Anyways, I also noticed that my belt was a bit long and the noise was from the tensioner bottoming out. Got a 1" shorter belt and haven't heard the sound since. Man do I feel dumb.
Old May 12, 2005 | 10:50 PM
Franklin2's Avatar
Franklin2
I am glad you figured it out.
Old May 13, 2005 | 08:02 AM
123michigan's Avatar
123michigan
gotta love them simple solutions they are the best
dn29626
21
Apr 9, 2014 05:44 PM
Zephyrhills Ford
44
Aug 4, 2010 03:05 PM
89_Brnko2!!
Bronco II
Jan 7, 2010 12:23 AM
redrock233
1997 - 2003 F150
Jan 16, 2006 08:59 AM
go_go_gadgit
Jul 23, 1999 01:13 PM
