Bronco II Ford Bronco II
Alternator upgrade
Old Jan 3, 2010 | 06:25 PM
89_Brnko2!!'s Avatar
89_Brnko2!!
Alternator upgrade
Im adding a second set of off road lights and i wanna add a high amp alternator to help with all the extra electrical demands.This is an alternator that i found that seems to have the correct mounting setup for my 89.Take a look and tell me whether yall think it will work or not.....thanks....
95A Ford Bronco Alternator
Old Jan 4, 2010 | 01:35 AM
kernel-panic's Avatar
kernel-panic
Did a quickie look-up, and got listings for 10, 12, and 2 o'clock adjusting ear positions. If the one currently in your BII is a 10 o'clock version like the one you found - and the hook-ups are exactly the same as your current alternator, you should be good to go! I know there is a swappable alternator from the Mustangs that will swap in, I believe from the 5.0 models, and I believe that it's year-to-year (i.e. an '89 Mustang 5.0 alternator for your '89 BII)....
Old Jan 7, 2010 | 12:23 AM
Kurtis K's Avatar
Kurtis K
Another good source for upgrading to the 3G alternator is RJMinjectiontech.com I upgraded my '88 F250 using thier alternator and kit. Worth the money IMO. You can source the alternator from the junkyard and use thier kit (or make your own).
FordMac1
Jan 10, 2017 07:36 PM
4EyedTurd
WTB - Parts & other
Jul 13, 2016 09:11 AM
nilzlofgren
Nov 15, 2015 05:24 PM
oldblue89
Feb 8, 2011 08:12 PM
batmanincoralville
Mar 22, 2004 11:22 AM
