Sponsored by: Real Truck
pyrometer bouncing around
Old May 9, 2005 | 06:53 PM
getnbz's Avatar
getnbz
i have Autometer pyrometer and it reads fine awhile then it bounces around like crazy.when it stops bouncing its goes right to where the reading should be it just bounces around. i looked at the thermocouple the shrink wrap over the connection is good but the braided part is touching the turbo pipe is that the problem? i looked for ground wire getting loose it was tight. is the gauge junk?
Thnx
Old May 9, 2005 | 08:06 PM
Texascadillac42's Avatar
Texascadillac42
If the braided part is worn down to the actual wire it is probably the problem. If not, Id send the gauge to autometer and have them check it out. Usually only costs a few bucks, and 9 times out of 10 they will send you a new gauge.
Old May 12, 2005 | 04:34 PM
nailerdog's Avatar
nailerdog
I had the same problem a while back with my pyrometer. Found the connection at the thermocouple to be somewhat loose. Tightened it up and it fixed it. Check at the gauge end too.
egrubb460
20
Nov 14, 2013 03:16 PM
hamiltonfighter
May 14, 2012 03:40 PM
deano-was-his-name-o
Dec 7, 2008 12:33 PM
96powerstroke
Dec 1, 2006 07:33 PM
VQ2Fast4U
28
Jul 16, 2006 02:16 PM
