A/C Evaporator core Replacement
Old May 9, 2005 | 04:14 AM
AGATE's Avatar
AGATE
Need some help with this one... My local shop has told me that the a/c evap. core needs to be replaced in my 1997 Explorer because it leaks,and the a/c will not hold a charge. They did the die test, and found the leak in the a/c core. Now I know that this item is in the same location as the heater core,question is....Is this something that the average guy can change, or should this be left to the dealership? They quoted me $300 for the part, and another $600 to install it. I found the same part at a A/C supply outlet for around $120 bucks.. Any Help????? Thanks
Old May 9, 2005 | 09:46 AM
Top Jimmy's Avatar
Top Jimmy
Whoa!
Unless you know exactly what you are doing and have the equipment, the A/C stuff should be left to a shop. IMHO. I have done alot of work on my '97 but left that one to my local dealer. I am pretty sure that there are even environmental laws that prohibit even the release of the refrigerant into the air. Thus, you need gauges and collection equipment to do this job properly.
By the way, I don’t have my receipt, but believe that my local Ford dealer charged around $500 for this repair, including parts, labor, and charging the system afterward. If by “local shop” you mean someone besides the Ford dealer, you might at least check with them first. If it was from the dealer, an independent may be able to do it for less.
Best of luck.
Norton72
Sep 5, 2019 02:40 PM
racer3022001
May 12, 2015 06:41 PM
redsuperduty
76
Jan 3, 2013 10:44 PM
1terribleshot
Jun 30, 2009 01:18 PM
trailor
1997 - 2003 F150
Feb 22, 2007 12:21 PM
