99 Ford Contour Accessory Electrical
Old May 8, 2005 | 11:30 PM
bartonl's Avatar
bartonl
I replaced the trunk light, and ever since then my interior lights,and radio do not work. I checked the fuse box in the engine compartment and all of the fuses look fine. Is there another fuse somewhere that I can check? I would hate to take it to the dealer if it is something really simple.
thanks, larry
Old May 9, 2005 | 07:00 AM
projectSHO89's Avatar
projectSHO89
There is a second fuse panel under the left side of the dash.
Check F34. If it blows again, good luck, because that circuit goes all over...
You can also visit contour.org for content that is specific to the 'tour.
Steve
Old May 9, 2005 | 12:25 PM
Franklin2's Avatar
Franklin2
If you just started having problems after you replaced the bulb, I would double check again to make sure it's the correct bulb, and the socket looks ok up inside. The wrong bulb could make the fuse blow and a socket that fell apart could also make the fuse blow.
beckman
25
Sep 7, 2018 10:58 AM
jjurva
Nov 14, 2012 01:24 PM
toastinloaf
Sep 27, 2011 09:16 PM
jwcorder
1983 - 2012 Ranger & B-Series
Apr 26, 2006 05:41 PM
jmac2480
Electrical Systems/Wiring
Jan 6, 2004 11:59 PM
