no brake lights
Old Dec 24, 2003 | 02:20 PM
jmac2480's Avatar
jmac2480
Question no rear brake lights
I have a 1995 F150 with not brake lights, turn signals or hazzard signals. The third brake light over the cab works. The bulbs and fuse in fuse panel checks good.
Any ideas would be appreciated.
Old Dec 24, 2003 | 10:19 PM
Duderoy's Avatar
Duderoy
Almost sounds like a problem with your blinker switch.
Old Dec 25, 2003 | 01:25 PM
Franklin2's Avatar
Franklin2
Yea, the infamous multi-function switch. The third brake light is hooked directly to the brake switch, but the brake lights run through the turnsignal/multi-function switch.
Old Jan 4, 2004 | 03:16 PM
OCShawn29's Avatar
OCShawn29
I just encountered the same problem. My front blinkers work, but blink fast. The rear blinkers, brake, parking, and reverse light does not work.
Would this apply to the turnsignal/multi-function switch suggestion?
Old Jan 4, 2004 | 03:51 PM
Duderoy's Avatar
Duderoy
probably not. sounds like a connector came un-hooked or something.
Old Jan 4, 2004 | 08:00 PM
Franklin2's Avatar
Franklin2
I would agree with the other poster and say no. The parking/running lights are a seperate circuit, as is the back-up light circuit. What is common to all these would be a ground somewhere on the bed, or like was suggested previously, a wiring connector or harness problem.
Old Jan 6, 2004 | 11:59 PM
OCShawn29's Avatar
OCShawn29
Thank you,
All set. It was a loose connection, took about 10 minutes to find the problem. I was off-roading, hit a couple of boulders, busted the rear end and pulled the plug located above the spare tire. Should have been smart enough to figure it myself, but what the hell.
Thanks for the advice!!!
Shawn
P.S. Free Repair Rules!
Roosterhuntin
2009 - 2014 F150
Feb 28, 2015 06:59 PM
mikeismadness
1978 - 1996 Big Bronco
Apr 11, 2010 12:05 AM
Vinford
Dec 10, 2009 08:43 AM
daandmv
Jun 2, 2008 03:22 PM
ettiee
May 10, 2007 03:17 PM
