HPOP Draining
Old May 8, 2005 | 06:41 PM
StevensPoint's Avatar
StevensPoint
HPOP Draining
My HPOP reservoir is still draining out and causing hard start after a couple days of sitting. It loses a little more than 1"/day when sitting. I just replaced the check valve ball and o-ring. I did not replace the seat because I don't think its possible to get it out. Is there anything else that would cause the HPOP to drain out?
Thanks for any help.
Old May 9, 2005 | 03:06 PM
bphillman's Avatar
bphillman
I have the exact same issue with my 94.5
Old May 9, 2005 | 09:46 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Shouldn't be...injector o-ring maybe. Does it smoke a ton when you start it?
Old May 10, 2005 | 12:38 AM
bphillman's Avatar
bphillman
my 94.5 doesn't smoke at all
Old May 10, 2005 | 07:01 PM
cookie88's Avatar
cookie88
FTE Emeritus
Your check valve is leaking then. It's only function is to prevent the HPOP reservoir from draining when the pump is off.
Cameltoe, did you replace the spring? Maybe seat pressure is the issue.
Old May 17, 2005 | 06:36 PM
StevensPoint
It only smokes a little on start up - not much at all. I replaced the injector o-rings about 1 year ago.
When I replaced the check valve I dropped the new ball in and filled the rest of the cavity with oil (no spring or plug) and let it sit. The next day it was still full. Didn't lose a drop, so spring pressure should not be the problem. Then I replaced the spring and plug. If it sits for a couple days it still drains out.............
Dieselgrowl
17
Aug 9, 2013 09:00 AM
FUJINAMI1293
May 25, 2013 01:41 PM
mark460
Oct 6, 2011 09:24 AM
robert kelsey
Sep 1, 2010 11:05 AM
StevensPoint
32
Nov 29, 2007 09:19 PM
