lpop question's
Old May 25, 2013 | 12:35 PM
FUJINAMI1293's Avatar
FUJINAMI1293
lpop question's
I had a couple question's. while cranking the lpop should supply oil to the hpop reservoir. If the lpop is bad would that cause the hpop reservoir to drain while cranking?
Also if the lpop is bad could that be draining the reservoir overnight?
thanks
Old May 25, 2013 | 01:41 PM
hydro man 17's Avatar
hydro man 17
There is a check valve in the HPOP reservoir that is supposed to keep oil from draining out of it. Could be it is stuck with some crud or the spring is weak if that is actually the problem.
TBag7295
Mar 17, 2019 10:18 AM
PW01
Oil & Lubrication
Jan 12, 2006 11:19 AM
StevensPoint
Jun 17, 2005 10:16 AM
SPELLY F150
Oil & Lubrication
Apr 22, 2004 08:20 AM
aritting
Escape & Escape Hybrid
Apr 9, 2003 07:37 AM
