Ballast resistor wiring
Old May 7, 2005 | 11:59 AM
82andBlueF150's Avatar
82andBlueF150
I've now burned up 2 coils in a month. Only thing I can think of is that it's a missing ballast resistor. The previous owner eliminated it. How does it wire up? I've only got a hot wire coming through firewall to the coil now. I see neat coil it looks like another wire is teed into the positive side. What do I do to put a resistor back in
Old May 7, 2005 | 12:13 PM
Torque1st's Avatar
Torque1st
Posting Legend
What kind of ignition system do you have, an old Duraspark or a TFI system? If the previous owner was in there changing things we need to know.
Old May 7, 2005 | 02:45 PM
82andBlueF150
82 with 351, I'd assume duraspark but not sure as it's a wells module and nothing left says, all I know is it's a cannister coil with the slide on big connector that has both wires in one
Old May 7, 2005 | 05:45 PM
onion's Avatar
onion
You Can Get A Univalsal Inline For About 5.00 At Oreillys I Hooked It Straight Up. Some People Said I Would Need More Volts At Start Up But I Have Not Had Any Problems Yet
Old May 11, 2005 | 09:18 PM
82andBlueF150
this has just gotten worse, replaced module today, got 1 mile, replaced coil again got 1 block and now seem to have no power to the ignition system. Sleeting and raining so I'll look again in the morning. Could it be start solenoid or ignition switch?
Old May 11, 2005 | 09:39 PM
85F_150driver's Avatar
85F_150driver
i used the diagram in the back of the haynes manual to change from tfi module ignition to the duraspark set up. I made me a wire harness and spliced into the old power wires from the tfi. I still have the square coil hooked up to it with no resister wire. It runs good until i hook up the vacume advance. When i get some more cash i am gonna add the resister wire and a round accel super coil and see what happens when i hook the vacume advance to it. I would say put a new resister in and see how it runs. The reason why i switched it over to duraspark is because my tfi set up kept burnin up coils. i went through 3 in about 1 hours worth of driveing.
Old May 13, 2005 | 08:27 PM
Chiefrider007's Avatar
Chiefrider007
The easiest way I see is to just get an aftermarket coil made to run on 12V, period. Duraspark uses 12V on the crank and 6V on run, or something like that. That's why the resistor prevents your stock coil from burning up.
horseburner
Apr 30, 2013 11:13 AM
kchaps72
Mar 17, 2009 11:22 PM
PaulzF150
Feb 10, 2005 03:06 PM
ClatonK
Electrical Systems/Wiring
Jan 4, 2004 03:51 AM
showle
Oct 24, 2002 11:03 AM
