77 highboy brake problem
Old May 6, 2005 | 10:47 AM
haten'chevs's Avatar
haten'chevs
I installed new master cylinder and brake booster, did new shoes in the rear and adjusted them, front shoes are good and I've bled them MULTIPLE times getting nothing but fluid. I still have crappy brakes, they need to be pumped at leat 3 times before I get any real good brakes. Would this happen if the parts guy gave me the caliper for the 2 piston fronts and not the 4 piston (which I have)? Any ideas as where to start to get this fixed?
Old May 6, 2005 | 11:22 AM
hatemakings/n's Avatar
hatemakings/n
Just wondering but did you bleed the master cylinder before install?
Old May 6, 2005 | 01:01 PM
ford-raised's Avatar
ford-raised
just a suggestion that might help.pump up brake pedal to get pedal height & hold pedal depressed fairly firm.if pedal sinks slowly away than master u installed may be by-passing.i have had bad jobber masters in the past(maybe due to reman processes?).caliper shouldnt be relevant if bled properly.good luck with it
haten'chevs
OH yeah forgot to add that too. Yes I did
Old May 6, 2005 | 01:32 PM
buzzbait65's Avatar
buzzbait65
I have never seen 4 piston calipers for these trucks, usually they are dual piston per side
sounds like the rears didnt get fully adjusted, adjust each then hit the pedal to center the shoes, recheck.....you should get a constant "slight" drag, you can usually hear it before you feel it
btw, the fronts are called pads
pads for disc brakes, shoes for drum brakes
Old May 7, 2005 | 10:20 PM
plowpusher's Avatar
plowpusher
does the brake warning light work if its on your prportioning valve is not centered you will have to center it to get good brakes to check the light turn the key to start the warning light should come on if it doesn't check it
Old May 8, 2005 | 02:29 AM
highboy 74's Avatar
highboy 74
I have never heard of four piston calipers on these years of trucks. Are they aftermarket calipers? The stock calipers should be dual piston.
Old May 8, 2005 | 02:46 AM
ford390gashog's Avatar
ford390gashog
i think he means 4 total correct and it sounds like fluid is bypasing somewhere lots of times the rebults will be honed to biggere than 1'' on accident but there are no oversize pistons made so they will just through in a 1" oiston in a bigger hole allowinf fluid pressure to escape
Old May 8, 2005 | 02:50 AM
ford390gashog
on another thought are you bleeding you brakes by yourself if so you need to people because if you pump it then come out of the truck to close the bleeder you will have sucked air in you need to pump 3 times and the last time leave your foot fimly on th brake pedal pushing it to the floor while the bleeder is closed by your helper it is also best ot shut the bleeder while a steady stream of fluid is still come out usually half way through the last pump.and make sure to use dot 3 fluid a from a clean container and never reuse fluid.did you also make sure to bleed the front calipers too and start with the longest line and work done to the shortest line
Old May 9, 2005 | 09:02 AM
haten'chevs
i do mean 4 total pistons (sorry about the confusion). I am NOT bleeding them by myself, we pump 3 times and shut the bleeder about halfway through the last pump. We're gonna get a different caliper (another new one) and try that-its all thats left!!
Old May 9, 2005 | 03:49 PM
buzzbait65's Avatar
buzzbait65
Maybe i have been doing it wrong for the last 20 years, but, you are supposed to pump it up, then open the bleeder, then shut it without moving the pedal during the opening and closing.....if you pump it with the bleeder open you will be sucking air in everytime the pedal comes back up
Old May 10, 2005 | 09:20 AM
haten'chevs
What I ment was, pump 3 times (or until pedal gets hard), hold it on the last pump, break the bleeder open, and close it while the pedal is still going down. If we get air we do this until we get nothing but fluid.
Old May 10, 2005 | 12:35 PM
tellico racing's Avatar
tellico racing
This may sound silly......But are the calipers on the correct side? The bleeder screw has to be at the top of the caliper. Don't ask if I have ever made that mistake....I ain't tellin'.
Old May 11, 2005 | 09:23 AM
haten'chevs
Ya know thats a good ? I didn't do anywork on the calipers but I also never really paid attention. I'll have to check that out tonight.
mgargiullo
15
Apr 2, 2014 01:13 PM
Lowdog
Jan 22, 2012 03:09 PM
Cabledude
Jun 22, 2010 11:45 AM
J.McConnell
17
Feb 19, 2009 11:17 PM
blacklab3113
Jan 18, 2009 08:13 PM
