Windshieldwasher Woes
Old May 6, 2005 | 09:01 AM
30over's Avatar
30over
Hello, I have a 77 Highboy 4x4 but I'm using a 76 F250 2WD cab. I have installed an intermitten wiper switch, which works well. I haven't been able to get the windshield washers to work yet. I have installed a new washer motor & tank, and checked the fuses. I don't have any power on the pig tail connector which plugs on to the washer motor.
Any ideas on what might be the problem with my system, where to test or what to look for? The truck hasn't had a tank and motor on it in years till now. Any help would be appreciated.
Thanks!!
Old May 6, 2005 | 10:06 AM
CodaSmog's Avatar
CodaSmog
did you ground it? I had the same problem.
Old May 6, 2005 | 11:05 AM
fordfury469's Avatar
fordfury469
make sure you hve power out of your wiper switch when you push in the ****
Old May 6, 2005 | 11:22 AM
30over's Avatar
30over
What did you come off of with your ground wire? Thanks
Old May 6, 2005 | 12:40 PM
30over's Avatar
30over
Hey Guys, I've got her spraying all the way on top of the cab now. When I installed my intermitten switch, I had plugged the little 2 wire connector on the wrong way. The black & white wire has to be plugged on to the green & black wire going to the pump for it to get power, AAAARRRRRRGGGGG .
Thanks A Bunch!!!
Old May 6, 2005 | 02:03 PM
04XL4x4RC's Avatar
04XL4x4RC
What did you use for the intermitten switch? I would love to do this to my 76 at some point.
Thanks,
Matt
Old May 6, 2005 | 04:13 PM
30over's Avatar
30over
Hi Matt, Just type in " 73 79 wiper switch" into ebay. Most of the time there are 2 or 3 of them on there. They usually go, anywhere from 25 to 40 bucks.
The intermitten wiper swich came on some of the 73 to 79 trucks like the XLT's and the Lariat's. It's easy to hook up. Just unplug your old switch and plug the intermitten one in and hook up the ground wire. It's that easy. It has a delay box made right into the harness with it.
Just make sure you plug the little 2 prong part of the switch back in right, so your windshield washers will work. I think, even the switches up to about the mid 80s's will work but, I'm not sure on that. Like I said, there's usually a few on ebay most of the time.
Good Luck!!
Old May 8, 2005 | 02:28 PM
04XL4x4RC's Avatar
04XL4x4RC
30over, I appreciate it.. I will get this done soon. Sounds like a great esy change for my truck.
Old May 8, 2005 | 02:41 PM
Mil1ion's Avatar
Mil1ion
There is a tech article about this swap in our tech article section
let it be known there are some FTE users that advertise their parts in the Classifieds.
To me Ebay is the last place to go, but that's me
Old May 8, 2005 | 02:45 PM
04XL4x4RC's Avatar
04XL4x4RC
Thanks, I will look at the tech articles and also the classifieds for the FTE advertisers.
Last edited by Mil1ion; May 8, 2005 at 03:10 PM. Reason: removed un-necessary use of quote
Old May 8, 2005 | 09:41 PM
plowpusher's Avatar
plowpusher
you can use the switch and timer box out of a 80-86 also but you have to change one wire and I can't remember which one
docman
Bronco II
May 5, 2013 06:24 PM
Skoiv
2009 - 2014 F150
Mar 25, 2012 07:22 PM
Escape055
Escape & Escape Hybrid
Nov 14, 2009 09:35 AM
philipk
Dec 25, 2008 09:55 AM
woods
Nov 4, 2005 08:08 AM
