Ontario Chapter Join Chapter>, Leader: loudfords
Can't Wait.....
Old 05-05-2005, 08:54 PM
kwboom's Avatar
kwboom
kwboom is offline
Can't Wait.....
Just got some work done on the Bronco this past week...
engine flush
Oil change
fuel filter
PCV valve (really needed)
and some small fixing
I had some major oil foaming going on and lots of leaks so I thought that there was really bad blow by and in need for a major rebuild. Well when I changed the PCV there went my foaming and I put in really thin oil (5w30) and a can of restore now I just have to drain the oil soon and put in something thicker, prob 15w40 or something like that. I have some new wires and plugs, cap and rotor to put on.
Now for the really really good part............
I did some stereo work for a local preformance/tire shop here in town and I got a really good deal for a stock size 2bbl Holly carb that I need to put on the Bronco...................
Just had to let you guys in on the good news
Old 05-06-2005, 05:25 AM
Beast12's Avatar
Beast12
Beast12 is offline
Well that's all good but what about your SAS (solid axle swap)?? Guess you gotta get more money eh?
-Matt
Old 05-06-2005, 07:42 PM
Dealford's Avatar
Dealford
Dealford is offline
If you want to go to a thicker oil, try 10w40 first. 20w50 is really thick oil for summer use. 15w40 is usually for diesels with different addatives.
AL.
Old 05-06-2005, 09:00 PM
kwboom's Avatar
kwboom
kwboom is offline
Beast I have been debating the SAS for a whyle, I have done some major research on it and come to find out that is you will loose alot of ride comfort and with all the travelling with camping, I think that is something I just might keep for a all time off-roader, and just do a small lift and buy bigger tires for this one.
Thanx for the tip Deal I might try the 10w40, I do alot of travelling and I want to protect this motor as long as I can. I have another block to build up but no$$$$$$ to do it with..
Amphihauler
05-15-2017 06:17 PM
J. E. C.
07-30-2016 02:32 PM
BigBlkEX
09-11-2014 03:35 PM
Jameson JC
1999 to 2016 Super Duty
07-26-2013 10:53 PM
bly8397
13
12-07-2012 08:49 AM
Quick Reply: Can't Wait.....
