Ranger '99 will not start
Old May 4, 2005 | 05:40 AM
davedawe's Avatar
davedawe
Cool Ranger '99 will not start
99'Ranger,3L., 5 speed, 2 WD.
Fuel and spark OK. PCM changed,12 volts to fuel injectors OK. No ground to fuel injectors. appreicate your help
Old May 4, 2005 | 10:22 AM
Rockledge's Avatar
Rockledge
No ground to all of the injectors? Have you pulled the connectors on each injector and confirmed that with a test lamp or noid light?
If something is preventing the PCM from delivering any of the ground signals, I would have to think the problem is electrical in nature, maybe along the lines of a bad Clutch Pedal Positon Switch or even a hiccup in the Anti-Theft system, those types of things. A WOT signal from the TPS while the engine is cranking also prevents the fuel injectors from firing, as well.
You don't mention how this problem started.
Old May 4, 2005 | 11:05 AM
davedawe's Avatar
davedawe
Ranger '99 doesn't start
At first, it wouldn't start, with gas pedal to the floor it started.
next it would start sometimes only, start,one day, start a week later.
now no start.
No ground to all injectors.
Does the computer control grounds to injectors thru PCM?
What is WOT signal?
Thanks
Old May 4, 2005 | 12:08 PM
Dave257's Avatar
Dave257
Yes the cpu controls the injectors by grounding one side to squirt fuel. I would look at the throttle position sensor.
Dave
Old May 4, 2005 | 02:22 PM
Rockledge's Avatar
Rockledge
WOT = Wide Open Throttle
The PCM controls the injectors by grounding each one, seperately, as needed.
Old Jun 26, 2005 | 06:33 PM
roadrage's Avatar
roadrage
I am having the same issue , although my ranger is a 94. I see that Davedawe found his issue, but unfortunatly, the TPS didnt fix mine. I have 38psi at the schrader, I am getting spark at every cylinder, but still no firing of the injector. Any other ideas?
Old Jun 26, 2005 | 06:43 PM
davedawe's Avatar
davedawe
The dealer replaced idle control sensor on my Ranger 99,3 L
Old Jun 26, 2005 | 07:24 PM
roadrage's Avatar
roadrage
Idle control sensor? I am not sure where that is. Yo uarent referring to the IAC are you?
Old Jun 26, 2005 | 08:24 PM
davedawe's Avatar
davedawe
Just checked work order on my Ranger '99 start problem from Ford dealer-
sorry I gave Wrong info should read
Throttle position sensor shorted
replaced CX1493 Potentiometer - ENGI part cost approx. $40.00US
I don't know location on engine
Old Jun 27, 2005 | 06:57 AM
pawpaw's Avatar
pawpaw
Davedawe, I noticed you've changed the PCM recently, did this problem begin afterward, if so, are you shure it's ground is good????
You could confirm the ground with a heavy gage low resistance jumper wire, from the computer to the chassis or back to the battery's B- terminal. If she starts you know there is a computer grounding problem.
Also check the wiring harness connectors for looseness, bent, pushed back, corroded pins or sockets.
If all that checkes out ok, maybe the replacement PCM is bad.
Run this ride by your favorite autoparts store for a computer scan, it should flag something that would narrow the search down.
