Rear Differental bolt
Old Jun 26, 2005 | 08:33 PM
Help I M Stuck's Avatar
Help I M Stuck
Ok..tried everything to get that 8mm bolt out of the rear so i can pull the axles out to replace the bearings and seals. I can't get it to move. I've got it out on other trucks..but this one is being stubborn. Anyone with any suggestions? If not then i'll just pull a junkyard rear and redo that..only plan on having the truck a few more months..then is HELLO F250 DIESEL Super Duty..
Old Jun 27, 2005 | 07:47 AM
Torsen Rick's Avatar
Torsen Rick
You mean the retaining bolt for the cross-pin? Ford uses thread locker on those. The best you can do is put a 6-point socket on it and fairly long handle. Then brace the diff from turning. It should come out, they can be a pain sometimes though.
