MAF Conversion Kits?
Old Jan 27, 2006 | 12:09 AM
  #46
Chevy_impala57's Avatar
Chevy_impala57
306 i like that idea take pictures of it when you done
Old Jan 29, 2006 | 12:17 AM
  #47
Peter94's Avatar
Peter94
well no wonder then. Thanks alot, i actually added a 2nd o2 sensor and ran another wire and pin into the computer. THanks alot!
Old Feb 2, 2006 | 08:01 PM
  #48
Chevy_impala57
cjjeeper, My Mustang intake has a peace of meatal covering the egr hole, and i want to have the egr because some one told me i will get worse gas millage and pinging,is this true? I was going to take one off a crown vic but i noticed there is no pipe goign to the one in the crown vic how dose it send the exhuasted gases back??
Old Feb 2, 2006 | 11:35 PM
  #49
cjjeeper85's Avatar
cjjeeper85
My truck is living proof that what you were told is 100% wrong, I have no egr, I get 14 mpg (around town), and I've done everything I can to make it ping, just short of advancing the timing to 20* and running 87 octane. The 5.0 car intake has internal egr passages and uses an egr spacer between the tb and the manifold that the egr valve attaches to.
Old Feb 3, 2006 | 01:08 AM
  #50
Chevy_impala57
Oh ic so if i wanted to i could just get the egr valve and with the lower intake on it will all work? I think i might try it with out , what did you do with the erg tube coming up fromt he truck?
Thanks mike
Old Feb 3, 2006 | 01:09 PM
  #51
cjjeeper85's Avatar
cjjeeper85
The mustang upper manifold won't work with the truck lower manifold, the runners are to different.(mustang runners are oval and truck runners are rectangular) If your gonna run the mustang manifolds then the egr tube goes in the scrap pile because it is no longer needed. Basicly to retain the egr with the mustang intake you need upper and lower manifolds, egr spacer, and the mustang style egr valve.
Old Feb 3, 2006 | 09:39 PM
  #52
Chevy_impala57
Oh ic i know i relaized that i have to use the lower intake, I have made up my mind and am going to ditch the erg and emssions all together.
Thanks for the info
Old Feb 4, 2006 | 07:33 PM
  #53
Chevy_impala57
Yeap, mass air computer,
mass air meter,
Ecm conector ( for the pins and to lern how it comes apart)or you could go buy some from ford.
You do not need to get the sefi injector harness from a mass air vehicle, crown vics were sefi and speed density , lincon town cars, cougurs, v8 thunder birds and mustangs. But you would most likely need to do some modification to it
The mass air harness is jsut 4 wires and is pretty easy to make. I ran 3 to the ecm , and one to a body ground and used a mass air plug from a 4.6 crown vic.
Old Mar 16, 2006 | 08:20 AM
  #54
76cougar74100's Avatar
76cougar74100
i would also be inerested in this conversion there is also some info on the fordmuscle website about a 5.0 maf conversion check it out.
Old Mar 29, 2006 | 08:35 PM
  #55
EgoMan's Avatar
EgoMan
You know the one thing that pisses me off about these MAF conversion articles?
They always say...If you have an e40d then you have some research to do...but for the sake of being easy lets do it with this way...
MY GOD THAT DOESNT HELP ANYONE!!!! Everyone has an e40d so WTF!!! There is nowhere that has difinative info on what to use exactly with a 351W and an e40d trans....NOWHERE. Basically if you have an auto from 92-95 your screwed! Why dont they just do it this way since theres more e40d;s out there? Sorry for the rant lol....its frustrating....I have to use a trans control unit and MAF kit just to get it to work thats like 1200 bucks total...PITA!
Old Mar 29, 2006 | 09:23 PM
  #56
cjjeeper85's Avatar
cjjeeper85
No you don't, all you have to do is use a mustang ecu to control the engine, and use the truck ecu as a piggyback to control the tranny. If you search (google is your friend) there is a company that makes kits to do it. (just don't remember who)
Old Mar 30, 2006 | 12:07 AM
  #57
EgoMan's Avatar
EgoMan
EH...in the end I like the transmission control unit due to its ability to be tuned. But non the less I had to do all the GOOGLE work and so on. Why cant they just do an article on how to do it with the e40d whithout having to pay double the price of the truck just to do it... 1600 buck for a Pro-M kit.....my got for what!! thats robery!
Old Mar 30, 2006 | 12:28 AM
  #58
cjjeeper85's Avatar
cjjeeper85
Swaping in an aod or a manual would be cheaper than that, not to mention eaiser.(I'm so glad my truck has an aod)
Old Mar 30, 2006 | 03:57 PM
  #59
EgoMan's Avatar
EgoMan
But an Aod isnt as tough as an E40d....not to mention that tall 2.71 first gear that the Aod doesnt have. As far as a five speed....to much hassle.
Old Mar 30, 2006 | 06:37 PM
  #60
cjjeeper85's Avatar
cjjeeper85
True, but for as much as it cost to do a stock rebuild on the e40d you can have one heck of an aod built.
