I need the OEM or aftermarket part # for a EGR solenoid to fit a 1994 2.3L Ranger. I've seen parts listed at some of the major parts retailers, but no picture provided so I can't be sure if it is what I'm looking for.
Are you looking for the EGR valve or the EGR sensor (a/k/a the DPFE)?
I've already bought both of those. The last item in the emission system looks like a vacuum solenoid for the EGR valve. I've posted a pic below of what it looks like, but it's from a contour not from my ranger, so I don't know the part #, but I do need that part.
Jinx: Try Rockauto.com. They seem to have an extensive supply of Motorcraft and Delco as well as after market parts. MOST of the parts have a picture.
I have personally had great service from Rockauto.
Russ
Thanks Russ, but when I did a search for the EVR at their site, this is the picture under the item (EVR) listed. Which by my understanding is the DPFE (which i've already replaced).
i found this searching for the number you listed. might not help but it looked interesting.
2) the solenoid/control valve that sends a regulated vacuum signal to the EGR valve. The EGRVR valve is mounted on the right-side (rear) of the engine. Part # XXX-9J459-XX. Change the X's to suit your model and build date.
just an fyi. some emissions parts are only available at the dealer. The pipe that runs from the exhaust manifold to the egr is only available at the dealer. i found that out by breaking the thing
Thanks for all the help everyone. I went to the dealer at lunch today and got the actual part# for my truck. I also found it on-line at Fordparts.com
FOTZ9J459A $25.89
Emission system - Egr system - Vacuum regulator
VACUUM REGULATOR, Ranger 1993 - 1994
The dealer wanted $40.58
Just a return FYI... I saw one on E-bay, with EGR valve included for $20, if you don't mind buying used.
FOTZ9J459A $25.89
thanks, i have a new egr but a broken pipe. i don't think it really matters if the pipe is used or not and i am sure the dealer would charge an arm and a leg for that stupid pipe
