Aerostar Ford Aerostar
Oil Sender
Old May 2, 2005 | 09:07 AM
C Holmes's Avatar
C Holmes
Oil Sender
Can anyone tell me if there is a simple way to change the oil pressure switch on a 92 4.0L engine? I know where it is (I Think) but how I could get at it is a mystery.
Old May 2, 2005 | 08:44 PM
eehoepp's Avatar
eehoepp
I am unfamiliar with the 4.0L V6, but if it's located in the same place as on the 3.0L V6, it's a breeze once you remove the engine access cover inside the van.
To remove the access cover, you will first have to unscrew the center console or those hokey cup holders (depending on how your van is equipped. There is also a black electronics box under the dash immediately above the access cover that also has to be unscrewed so you can remove the access cover once it's unlatched.
My Haynes manual shows four latches on the engine access cover - two on the driver side & two on the passenger side. My 95 Aerostar only has one on the driver side, though for a total of three.
It takes a bit of practice to get the cover back in position once you are finished - the top edge tends to hang up inside the hole.
Good luck with your repairs.
Cheers,
Eric
edit: I just read the other thread on oil pressure sending units. Please disregard the above.
Old May 2, 2005 | 09:25 PM
DaveMac2Vans's Avatar
DaveMac2Vans
Any clue what that box is?
Old May 3, 2005 | 01:28 AM
copper_90680's Avatar
copper_90680
RABS control module.
Also, the oil pressure switch on the 4.0L is extremely well hidden below the P/S pump. I suspect one must take the pump and bracket off to remove that switch, unless you have extremely small dextrous hands and fingers with 10 joints instead of 3. On the other hand, don't blame the switch yet. Pull the connector off and clean it well. That's all it took for me.
Old May 3, 2005 | 01:47 PM
krankshaft's Avatar
krankshaft
And on the 3.0L engine its behind the engine cover on the passenger side of the engine its a brass colored (goldish) colored plastic can with a metal bolt at the base so it can be removed with a wrench it protrudes 1 1/4" from the engine block and has a wire connected to the top of it with a bolt.
Once you've loosened it just unscrew it by hand to get it out of the block.
Although if yours is old it will be grimy and black like everything else .
Old May 3, 2005 | 09:09 PM
cbr900's Avatar
cbr900
Hi there, the oil pressure sender unit is were copper said it is, you have to use a short ring wrench to get at it, I forget which size it is but I thing it is 19,20 or 22mm and it does come out easy once you have it lose make sure you put pipe thread tape on it when you put it back.
Old May 4, 2005 | 06:36 AM
C Holmes's Avatar
C Holmes
when you say ring wrench I assume you mean box end wrench is that right?
Old May 4, 2005 | 11:05 AM
krankshaft's Avatar
krankshaft
Yes I thats what it means box end wrench haven't heard it called that before.
Old May 4, 2005 | 11:15 AM
copper_90680
Yes, we Americans call it box-end wrench. You are from New Jersey, so you call it something else Just kidding, Krankshaft, it's been a slow day
Old May 4, 2005 | 07:32 PM
cbr900's Avatar
cbr900
ring wrench
ring wrench is what we called them in england, in fact we called them a ring spanner, but I thought I might confuse the issue if I said that.
Old May 5, 2005 | 06:17 AM
C Holmes's Avatar
C Holmes
I never did get that whole spanner thing
Old May 5, 2005 | 04:47 PM
cbr900's Avatar
cbr900
spanner is all I have ever known.
matowns21
19
Dec 30, 2011 09:27 AM
powerman01
Jan 23, 2009 04:08 PM
Adam0331
40
Aug 31, 2008 09:09 AM
rmcmillion2006
Dec 12, 2007 11:42 PM
wresleu
Aerostar
Jan 23, 2006 12:52 AM
