10K mod question
Old May 10, 2005 | 08:46 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I used to have both the 5.6 and 10K resistors on a toggle, but my current chip revision is turned up enough that the resistors were pretty much worthless on the high setting. In fact, the 5.6K cost me 12 HP on the dyno so the resistors and switch are in the toolbox.
Old May 10, 2005 | 09:22 PM
pdkloste's Avatar
pdkloste
The reed switch is just a small cartridge type of switch that completes or opens a circuit when it receives power. I used a +5v switch (normally open)from Radio Shack that I spliced into the IVC on the throttle pedal. You want the switch to complete the circuit once the IVC switch kicks in.... the IVC switch will have +5v going into it on one side, and return to the computer on the other. On my 97 the Gry/Blk wire is the return voltage to the computer... I tapped into that wire for the reed switch. When the idle switch kicks on, about +5v returns to the computer.
Probably more than you needed to know...sorry about rambling on.
Old May 11, 2005 | 09:33 PM
cookie88's Avatar
cookie88
FTE Emeritus
Rambling?!?!? That is exactly the kind of stuff we need to know. It's what makes the site work so well. There is no such thing as too much information.
Old May 12, 2005 | 09:23 PM
pdkloste's Avatar
pdkloste
Thanks Cookie..
I know that I have learned quite a bit from this site...
Epd444
May 27, 2009 01:27 PM
Todd525
20
Oct 1, 2007 02:54 AM
gomfrddy
Feb 13, 2007 02:01 PM
cam1394
Feb 11, 2007 10:32 AM
Scott S
Oct 28, 2005 12:00 PM
