probably a dumb? but...
Old May 1, 2005 | 02:37 PM
sickchuck's Avatar
sickchuck
are exhaust pipe diameters i.d. or o.d. for sizes. need to change my cat and don't want to order wrong size
Old May 2, 2005 | 12:13 AM
MemOrex's Avatar
MemOrex
ID (In Diamater) is the size of the pipe that's going into the cat, OD (Out Diameter) is the size of the pipe after that cat.
Old May 2, 2005 | 11:11 PM
toyscout2's Avatar
toyscout2
Hi,
ID is the inside diameter of the pipe, not the size of the pipe going into the converter. OD is the outside diameter. Fortunately, it does not matter much which you use. If the size of the cat and the pipe say the same thing, don't worry about ID or OD. You can bump up a pipe to make up for a ID/OD difference with a exhaust pipe expander.
Old May 3, 2005 | 01:50 AM
351M's Avatar
351M
All pipes are measured in O.D, it you order a 3" magnaflow cat, 3" pipe will slide into the sleeves on that cat.
cadunkle
Mar 11, 2017 06:29 PM
BII Plow Truck
Feb 17, 2017 01:52 PM
rockhound_jb
Mar 3, 2016 05:16 PM
3KIDDAD
Jan 27, 2007 05:58 PM
DUALLYNOTED
Sep 1, 2006 01:03 PM
