Removing Drag Link
Old Apr 29, 2005 | 09:27 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
Removing Drag Link
I want to take the drag link off my parts truck. I have pulled the cotter pins out of the ends but I can't get the large screws in the ends to move. Any secrets? Is there a tool made the fits that large slot? I bent two screwdrivers putting them in sideways and trying to turn the ends. I want this one in one piece I noticed the drag link on my F3 is bent.
Old Apr 30, 2005 | 07:34 AM
barry's Avatar
barry
Soak it with PB blaster or equivalent. They make a socket with a straight blade screwdriver tip for this purpose. You're on the right track. See if you can find one. I've bent screwdrivers doing this. So many of those links are bent.
Barry
50 F-1
Old Apr 30, 2005 | 07:50 AM
Christopher2
Veteran: Navy
Smile
I am going to soak mine in WD-40 since that is all I have on hand. I am contemplating getting a torch to help with problems like this.
Old May 1, 2005 | 10:00 AM
51dueller's Avatar
51dueller
I've used a tire iron that has a flat blade on the end with success. It's about a foot long.
Old May 1, 2005 | 10:07 AM
Christopher2
Veteran: Navy
Thanks, hadn't thought about that. Maybe I can get one of those four way ones with a blade on one end.
Old May 1, 2005 | 12:24 PM
Earl's Avatar
Earl
If you can only find a four-way socket wrench, grind one leg down to a screwdriver tip.
Old May 2, 2005 | 12:49 PM
AXracer's Avatar
AXracer
The draglink is SUPPOSED to have a slight bend in it! If soaking in liquid wrench for 24-48 hrs (note to all: WD40 is NOT a penetrating oil!) doesn't do it then heat is your next option. I've had good luck breaking them loose with a dull chisel and hammer, put it in the uppermost end of the slot at as much angle as possible and give it a few taps. move to the bottom of the slot and do the same in the opposite direction. Keep alternating back and forth until it loosens, then take it out with a tire iron. If you need to heat it, heat the outside hot, then hold an icecube against the plug to shrink it.
You can also make a turning tool by grinding the square end of a short 1/2" drive extension (grind it from corner to corner to get a longer blade with less grinding and don't overheat it.) Keep the blade as short as possible and as thick as the slot.
SuperDuty93
May 13, 2012 11:38 PM
LedheadELH
Jun 27, 2009 10:54 PM
tangcoral2004
Jul 1, 2005 04:21 PM
50F2
Apr 30, 2003 11:47 AM
