Adjusting Gear Selector Pointer
Old Apr 29, 2005 | 03:31 PM
edward r's Avatar
edward r
On my 02 EXPl XLT I just replaced the tranny. Now the pointer on the dash (P R N D etc) is slightly off. How do i adjust this so the pointer is more correct (it now points in between the letters as opposed to directly at them which drives my wife crazy)
Old Apr 29, 2005 | 06:28 PM
don96exp's Avatar
don96exp
I haven't seen the set-up on the '02 but most earlier Ford products have a cable from indicator to the steering column. They had a thumb wheel located where the cable attaches to the steering column. I hope this is the case on your '02.
Old Apr 30, 2005 | 01:24 AM
spicy429's Avatar
spicy429
I'm having the same problem with my 99 Sport
also had it with a past vehicle, it was an easy fix.
Old May 2, 2005 | 12:23 PM
edward r's Avatar
edward r
do you have to take the steering column apart to get at the thumb wheel ?
Old May 3, 2005 | 09:37 AM
don96exp's Avatar
don96exp
No, you should be able to get to it by removing the lower panel of the dash.
Old May 3, 2005 | 09:40 AM
mason's Avatar
mason
I have done this on a Mercury van when the cable broke and it's not too bad. I do remember having to remove the lock cylinder to replace the cable. Be sure to disconnect the battery any time you work around the steering column.
Mason
cntroes
Mar 31, 2015 04:34 PM
centralNH
Mar 13, 2014 05:02 PM
jhelm2586
17
Nov 23, 2012 04:18 PM
shorebird
General Automotive Discussion
Sep 20, 2012 07:51 AM
Notmeofficer
Jul 21, 2011 03:24 PM
