96 f-250 oil pan replacement
I replaced it on my 351w and it was a bitch. I tried to just jack the motor up high enough. Took the intake off and disconnected everything. I got the old pan out with not much trouble but the new pan would not fit back in. I ended up pulling the motor out, which of course opened up even more problems. So good luck, it can be done, make sure you mark everything you disconnect.
That was hilarious!
Anyway, there's always been talk amongst us about how difficult it would be to dismantle the frame/suspension versus lifting the motor. I don't know what the front end looks like on a 96 but maybe you'd want to consider that option?
I was suggesting you take the time to disassemble it. I don't know how difficult it would be, but it wouldn't hurt to consider it before you go to the trouble of prepping the motor to lift it.
For the record I strongly advise you to NOT torch and weld the crossmember.
Uhm... I wouldn't torch it and weld it back in. That is, I wouldn't do it that way. If I'm not mistaken the cross member you're talking about is tied into the suspension. Cutting it out and welding it back in could result in huge issues with the system.
There is a shop by me that CUTs OUT the crossmember to replace powerstroke oil pans in superdutys all the time.I think they are NUTS and there is no way i would let some one torch my frame then weld it back in
Agreed. And you would think a shop would know better. Seems to me it would be easier to pull the motor and would definitely create less liability for the shop in the event that something should happen after they did this. Maybe there's more room on a superduty but it seems to me that they would only be able to weld it back in place from the bottom side as there wouldn't be enough room on the top.
Is that just on the 96 or older models too? Just curious 'cause I'm trying to find the time to replace the oil pan gasket on my 91 F150 and I was thinking about dismantling the suspension to do it, but if it's welded in place then there's no point in bothering. I just haven't had a chance to really look closely at it to see if it is- I just assumed it wouldn't be.
