Sponsored by: Real Truck
Tranny position pointer adjustment
Old Mar 30, 2015 | 07:52 PM
cntroes's Avatar
cntroes
Well got the shift linkage adjusted so the truck starts in park now but I need to back up the needle a tad bit to be accurate. Anyone out there know how to do that on a '99 F250?
Any help is well appreciated.
Charles
Old Mar 30, 2015 | 11:06 PM
cornell5's Avatar
cornell5
Charles,
I just did mine today. If you look up way under the dash right below where your cluster gauges are there will be a white dial.
I shifted into 1st gear and adjusted till it was centered than ran through the gears to fine tune.
Old Mar 31, 2015 | 03:50 PM
cntroes's Avatar
cntroes
Originally Posted by cornell5
Charles,
I found the black adjusting wheel located on the cable, unfortunately the nylon adjusting wheel housing is broken. Trying adhesive but generally doesn't work on nylon. Can't find the replacement part at auto zone unless I am searching for the wrong item. Any ideas would be great.
Charles
Old Mar 31, 2015 | 04:34 PM
clem1226's Avatar
clem1226
Try part number F81Z7A110CA on eBay. Or a local dealer, or here http://parts.autonationfordwhitebear...rd/f81z7a110ca
rwdfan
Sep 21, 2011 04:30 PM
racerx6466
1997 - 2003 F150
Aug 4, 2009 04:28 PM
Jager
Sep 8, 2008 02:39 PM
Douglas DC-9
Mar 14, 2007 05:51 PM
redeye rye
Sep 24, 2004 08:21 PM
