cleaning fuel injectors
Well if they are ok or not, would depend on which multiplier you had the ohms scale set to.
Was it set on X1, X10, X100, X1000, x10,000, when you took the readings?????
To determine the resistance you read, you would multiply the numbers you got, by the scale multiplier you have the ohmmeter set to.
If it was on the x1000 ohms scale and was steady when you flexed the wires, your likey ok, as the rule of thumb, for resistance type spark plug wires its 1000 ohms per inch of length, 30,000 ohms max.
If you were on the X10,000 ohms scale, the resistance you got is too high, as they shouldn't measure more than 30,000 ohms, no matter what the length.
If the plug wires resistance is too high, it can make for a weak spark that can get blown out under stress & cause a miss or poor combustion, thus poor power & poor gas mileage.
I check ALL my new plugs & wires resistance right out of the box, before I install them.
I've seen & heard of plenty of bad parts right out of the box, so I never assume they're good, just because they're new!!!!
Fellow on the MotorWeek forum last year, bought & installed new wires & plugs for his truck, only to find it ran much worse.
Upon carefull checking, did he found one of the pug wires plug end contact wasn't even fastened to the wire. When he tugged on the boot a little, it pulled right off.
The conductor was stuck into the contact, but never crimped tight. So much for quality control!!!! LOL
Anyway I never trust anything new right out of the box, it's untested by time & thus unproven, as far a I'm concened, so it's gotta prove itself, thus I begin with testing them, or having them tested, if at all possible.
If I get another alternator, starter, relay, ect, ect, I have the store test em BEFORE I leave the premisis. LOL
Are these the #1 cylinder plug wires????
Are you certain the #1 plug is properly gapped????
Yes those are the #1 cylinder plug wires- that's where the misfire is according to the po301 code that it's giving. I have done EVERYTHING else that I can think of. They are new wires form autozone (cheapies) with a lifetime warranty. Should I take them back and have them replaced? I did not gap the plugs because I assumed they were pre-gapped (autolite double platinums). What should the gap be? Thanks.
Also, FWIW, there is a wire harness that runs underneath the driver's side of your truck that can cause a variety of engine issues if it starts chafing against the undercarriage. It might be worthwhile to take a peek under there even if just to rule it out as a possible cause:
https://www.ford-trucks.com/forums/s...d.php?t=315257
Dave
Dave
joelford, have you tried swapping the #1 injector with another cylinder?
I just this past weekend replaced the #1 injector. I just have a really hard time believing that it is something major like valves or internal engine. I have owned the truck since it was new, driven it very easy, and always been diligent about changing the oil. Furthermore, sometimes it runs nearly perfect. I drive this truck daily, and it never quits, it just has that slight miss usually. Lately it doesn't idle as smooth as it did and seems to ping more on hills and under hard acceleration if this helps at all.
Dave
I am having a problem with u 2000 Ford Explorer. It has a 4.0L engine and 200,000+ miles on the odometer. The vehicle originally came to our shop will the Check Engine light on and a DTC P0301 (cylinder No, 1 misfire) stored in the PCM's memory. The spark plug wires and spark plugs looked, pretty bad, so we recommend a major tuneup. We cleared the DTC and returned the vehicle to tlie customer.
The engine ran fine for a month or so before the customer returned because the Check Engine light was on again. This time a DTC P0304 (cylinder No. 4 misfire) was stored in memory. We suspected a defective ignition wire because the wire travels under the upper intake plenum to reach the No. 4 spark plug. After replacing the wire and clearing the DTC, we returned the vehicle to the customer. A couple of weeks later, he was back for the third lime, this time with a DTC P0301 in memory.
Inspection of the engine and related systems revealed a fuel pressure of 65 psi. Hot cranking cylinder compression ranged from a minimum of 130 psi to a maximum of 150 psi for the six cylinders. A relative (running) compression test also appeared normal. A smoke machine was used to check for vacuum leaks (none ware found).
We had installed a set of injectors during the vehicle's second visit because testing on a flow bench indicated the No. 1 injector wan weak. Scan data since then has never indicated an injector failure, but I've noticed that the injector pulse width seems wider than normal at times, at approximately 4.5mS. The oxygen sensor is switching normally from .2 to .9 volt, indicating the PCM is in control of the fuel mixture.
While consulting my service information, I found a Ford technical service bulletin that recommended valve spring replacement. A friend at a neighboring shop suggested that an intake manifold vacuum leak also might be to blame. There's supposed to be a TSB on that problem, too. What do you think?
Ignacio Gonzalez
Address not given
You've thrown a lot of information at me, Ignacio. Some of it may relate to the misfire problem and some may not. Let's start with the TSBs. Explorers, Rangers and Mercury Mountaineers of this vintage are equipped with one of three engines: a 5.0L V8 and two different 4.0L V6s. One of the V6s has overhead valves, while the other has single overhead cams (SOHC). It's important to know which engine your customer has before consulting the TSBs, because the bulletins may apply to one engine or the other, but probably not to both.
The TSB involving the intake and exhaust valves (Ford TSB No. 02-3-2) applies to the 4.0L SOHC engine only. Affected vehicles set a DTC P0300 or P0301. When die DTC is set is veiy important, which is why it's essential to consult the freeze frame data stored in the PCM before clearing any misfire DTCs. Once the freeze frame data is gone, there's no way to recover it until the next time the problem occurs.
In this case, the problem (misfire) must occur at an engine speed greater than 4800 rpm. This type of misfire (and the resulting DTC) occurs under heavy acceleration, due to higher-than-expected transient exhaust system backpressure, coupled with valve spring resonance points. In simpler terms: The exhaust valves may hang open slightly, causing the misfire. Install the updated parts to correct the problem, but bear in mind that this will correct an engine misfire problem above 4800 rpm only. If freeze frame data indicates your customers engine is misfiring at a lower rpm, look elsewhere.
Intake manifold gasket leaks were handled under a full-on Ford campaign (TSR No. 0OM12). Ford covered its 1997-2000 vehicles for six years or 72,000 miles, so your customers Explorer is unfortunately no longer covered. Once again, this TSB applies to the 4.0L SOHC engine only. Consult the TSB for information on updated gaskets and a camshaft chain tensioner, as well as installation instructions.
Leaking intake manifold gaskets on this engine often produce rough running complaints when the engine is cold. The leaking gaskets admit unmetered air, diluting the mixture and causing a misfire. As the engine warms, the gaskets may swell enough to seal a little better and the engine smoothes out. The symptoms won't return until the engine is allowed to cool.
If you don't have a smoke machine to check the intake manifold gaskets, simple carburetor cleaner will do the job. While watching the short-term fuel trim (STFT) for each bank with your scanner, try spraying the carb cleaner near the intake manifold gasket mating surfaces (upper and lower gaskets). Watch for big changes in STFT, as the PCM attempts to compensate for the sudden addition of uninvited fuel.
Them's one final thing you mentioned that may relate to die misfire DTCs: the abnormally long injector pulse width. You indicated that the injectors had been replaced, but not whether they were new. If the injectors are clogged or are receiving inadequate fuel pressure or volume, the PCM will respond the only way it knows how-by holding the injectors open longer. But this helps only if longer equals more. I only a trickle of fuel is making it through tho injectors, it won't matter how long they're held open. An inadequate fuel supply caused by clogged injectors, a clogged fuel filter or a weak fuel pump means a leaner-than-normal fuel mixture. And that can lead to what? Repeat alter me: misfire!
Copyright Hearst Business Publishing Dec 2004
Provided by ProQuest Information and Learning Company. All rights Reserved
-- Ignition system.
-- Fuel injectors.
-- Fuel pressure.
-- Evaporative Emission System.
-- EVAP canister purge valve.
-- Base engine.
-- Running out of fuel.
Dave
The clue you gave about it misfiring under load, is usally associated with plug or plug wire problems, so those had to be eliminated first.
Anyway good to hear it's finally put right. Makes you feel mighy good to win one once and a while, desn't it.
