Power Window Install Question
Old May 17, 2005 | 04:19 PM
Jmorrell588's Avatar
Jmorrell588
I just bought a Power Window Kit from Electric-Life For my 1991 Ford Ranger 3.0.
My question is this... It says to connect (RED) wire to the ignition Switch. Where and how would I locate and attach this to the ignition switch? Does this mean I have to attach it to the Panel box under the hood ot the fuse box under the dash and at which location? I thought this would be easy. But as usual, it is so not that easy now. The Blueprint stops at that point and does not go into detail where it might be located.
Also it has the (Red-Blue) wire connecting to the Dash Light. Where and how would I locate and attach this as well? The ground wire was easy to figure out. Thank you for any help you might provide.
Jimmy
Old May 18, 2005 | 12:00 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Well, I have no clue how to deal with aftermarket. But you might look at the wiring diagrams found in the repair section on autozone.com and see if that helps steer you in the right direction.
superduty4x4
15
Sep 6, 2021 10:50 PM
delorenzomp
Electrical Systems/Wiring
Oct 22, 2014 03:29 PM
Bftford
Dec 15, 2013 01:07 PM
atomicjoe23
46
Feb 27, 2009 07:58 PM
