stereo equipment
Old May 19, 2000 | 06:47 AM
fishmanndotcom's Avatar
fishmanndotcom
stereo equipment
What is a real good system to put in my 93 F-150 extended cab?
Old May 21, 2000 | 12:54 AM
LX96TBIRD's Avatar
LX96TBIRD
stereo equipment
Well dude I personaly own a 96 F150 super-cab and i'm running 2 10" Bazooka Tubes in the rear floor board. They sound nice and truly Hit hard. Especially if your playing AC-DC on the stereo.
All my amps are custom placed under the rear bench seat. I have a Nakamichi CD, AudioControl EQL, MTX Crossover, MTX Thunder4160 running Mids and Highs, and Alpine bridged mono running Bazooka Tubes.
P.S. I've personaly blown alot of tweeters and i replace them with "Radio Shack Surface mount Tweeters" they work just as good as the infinity tweeters i previosly had before. and they're only $20 a pair.
Old May 22, 2000 | 03:58 AM
pffourn's Avatar
pffourn
stereo equipment
I have a '96 F-250 with an AM/FM radio. I am upgrading to an in-dash cd player and wanted to know how to get the old radio out without taking the dash all apart.
Old Aug 9, 2000 | 11:04 PM
swaz's Avatar
swaz
stereo equipment
Ok, I just finished installing a system in my '95 extended cab. To answer both of the current questions here:
To get the stock radio out, get the DIN Removal tools (I borrowed them from the Ford garage, but even WalMart sells them) and pop the stereo right out. I am assuming that the '93 is the same as the '95 (4 small holes). Mine was stuck on the passenger side - didn't want to come out. I popped the glove compartment open (pop it down all the way) and stuck my hand in there to help release the little clips that hold the stereo in. It's a tight fit if you've got big hands, but it needs to be done sometimes.
Now, for a decent system: My truck took 6.5" speakers in the doors and 5x7 speakers in the rear. I bought all new Blaupunkt Overdrive (3-way, 200W peak) speakers for all 4 corners. Make sure you either get the factory speaker adapters or else you'll end up cutting the factory harness and soldering the new wires on. I recommend buying everything through Crutchfield, as they will include EVERYTHING (trim kits, manuals, DIN tools, etc.)
For a CD changer/Cassette player, I bought a Sony Xplod CDX-737 10-disc CD changer and mounted it underneath the middle front seat in my truck. May not work if you have bucket seats. I got the Xplod CDX-7350 Tape deck/tuner/cd-controller for the dash. Looks good, sounds great. Has 2 sets of preamps and the built-in CD-changer controls. Even without amps installed it will blow away the stock system - believe me.
I will soon have amps and subs ordered, and will install all of them underneath the back seat... but so far I have under $525.00 invested and I have one heck of a system. Hope this helps a little.
-Ryan
Old Aug 9, 2000 | 11:33 PM
hotrodford_88's Avatar
hotrodford_88
stereo equipment
I bought a set of speakers made by Pioneer specifically for Fords. They're 6x8 and fit the factory speaker mount/cover in the 92 & up Ford pickups perfectly. Plus they do sound good.
Check out September 2000 issue of Truckin' magazine they did an upgrade on a 99 F-150 Ext Cab. And used all Pioneer components (amp, front speakers, & rear speakers, plus an 8 inch sub in a custom built box under the back seat.
You might be able to find the article at:
http://www.truckinweb.com
Look under the tech section for the 25th anniversary project truck.
Good luck
Old Aug 10, 2000 | 10:20 AM
joseph's Avatar
joseph
stereo equipment
what speaker size goes in the xcab the 5x7 or the 6x8? which one bolts right into the old location the best?
also can you get to these speakers through the factory grill or do you have to pull the entire rear panel?
Old Aug 10, 2000 | 10:22 PM
hotrodford_88
stereo equipment
[font size="1" color="#FF0000"]LAST EDITED ON 10-Aug-00 AT 11:24 PM (EST)[/font][p]The 6x8 speaker is made to fit Ford & Mazda.
All you have to do is remove the four screws holding the speaker grille on the rear panels, and the whole speaker / grille assembly will come out. take the four screws out of the back of the speaker and take it off of the grille.
I got the Pioneer 6x8 inch speakers from Summit Racing. The part number Summit lists is:
PNR-TS-A6813
The price is $79.95 a pair & Summit only charges 6.95 for shipping. (no handling charge) And everything is shipped UPS ground unless you want it faster.
These are good speakers, I put a set in my reg cab 88 F-150 when I installed the Pioneer CD player. I'll have to replace the front 5 1/4" speakers now as they are almost blown out! I have no idea what the front speaker size is for a 92-96 model but you can probably find a good speaker that will fit the factory opening so you don't have to cut your doors all up.
Hope this helps
Old Aug 10, 2000 | 11:33 PM
swaz's Avatar
swaz
stereo equipment
Semper Fordelis
Michigan Chapter
13
Mar 11, 2011 01:48 PM
oldblue18
Appearance & Dress-Up
Feb 16, 2002 08:38 PM
darkknight
Jun 9, 2001 08:42 PM
BigBrownTruck
Jan 8, 2001 06:19 AM
Dylan Schwilk
Dec 21, 1999 11:20 AM
