steering wheel puller
Old Aug 19, 2000 | 03:37 PM
tmcalavy's Avatar
tmcalavy
Hey guys,
I need to pull the steering wheel on my 90 F150 XLT supercab and replace the plastic piece that cancels the turn signals automatically. I have the cruise control steering wheel. What's the best steering wheel puller to use with this truck? Is there a cheap, safe way to do this without a puller?
Old Aug 19, 2000 | 03:44 PM
AlM's Avatar
AlM
Old Aug 19, 2000 | 06:52 PM
Torky's Avatar
Torky
Are you sure you need to pull the wheel? That it's not the Multifunction Switch (includes turn signal) that is the problem? The MF switch has a plastic piece and spring that engages the column bit. If you already have the MF switch off, and see that the column part is broken off, then disregard.
Old Aug 19, 2000 | 06:54 PM
Torky's Avatar
Torky
If you have an airbag, don't forget to pull the negative battery cable off, and wait about 5 minutes first.
Old Aug 19, 2000 | 11:09 PM
PAUL_2's Avatar
PAUL_2
Tim ,
Youll need a puller that allows you to thread a couple of bolts into the wheel and then thread the center part of the puller down against the stud and use a socket to pull the wheel off . Its on just enough that you have to use a puller . I think the nut is 15/16 , Also I think you ll need 2 5/16 bolts , to thread in the wheel to use with the puller . Just a few turns of the puller & the wheel should pop off .
Shadowrider123
16
Jan 2, 2018 06:02 PM
creedua
19
Jun 11, 2014 01:01 PM
Daviddc114
Feb 4, 2011 12:20 PM
StevoF1
22
Nov 30, 2008 08:41 AM
Nawlins56_F600
Feb 25, 2004 02:26 PM
