Fuel Injector Cleaning
Old Aug 18, 2000 | 08:09 PM
ajstephan's Avatar
ajstephan
I have a '95 F150 4x4 with ~90K miles on it. I periodically put some Slick 50 fuel injector cleaner in, but I was wondering if I should do a more thorough cleaning by pulling the injectors and possibly even the intake unit (TBI?)
Anybody have any recommondations? Any help would be appreciated.
Old Aug 19, 2000 | 12:53 PM
PAUL_2's Avatar
PAUL_2
Does your truck run Ok ? One thing to consider is over use of commercial fuel injector cleaning products . Once a yr is adequate , anymore often & those products will leave a residue on your plugs . Plus your engine as Deposit Resistant Injectors . Taking them out to clean , IMHO , would be a waste of time . I beleive most all fuel has sufficient cleaning agents .
Old Aug 19, 2000 | 03:44 PM
AlM's Avatar
AlM
Our Broncos (i have a 96) are self cleaning .read that in a few manuals.
Old Aug 19, 2000 | 05:00 PM
ajstephan's Avatar
ajstephan
No, my truck doesn't seem to run poorly, but poorly functioning injectors would gradually get worse, and the change would be to subtle to notice. I drive almost exclusively in town, so carbon and other build up might be greater, especially at 90K miles.
I'll do some checking to see if the '95 injectors are self-cleaning as well.
Thanks for the input.
Old Aug 20, 2000 | 01:57 AM
PAUL_2's Avatar
PAUL_2
Well , I have always found fuel injectors very reliable . As long as you keep the rest of the maintenance items in check and take care of your truck I dont think you ll have to worry about the injectors causing you a problem .
Old Aug 20, 2000 | 10:18 AM
insect2's Avatar
insect2
PeterTheWolf
2004 - 2008 F150
Apr 26, 2012 03:57 PM
DrFord
Nov 21, 2007 01:26 AM
jhemker15
Sep 2, 2005 08:38 AM
Monty06
Bronco II
May 19, 2005 07:28 PM
jetmech1999
Aug 27, 2004 02:57 PM
