Pulling steering wheel
Old Mar 17, 2014 | 03:15 PM
Shadowrider123's Avatar
Shadowrider123
I cant seem to find a wheel puller small enough to do the job.
My HF puller is to big and I borrowed pullers from two friends and those are to big as well.
Where are you guys getting your puller?
Old Mar 17, 2014 | 03:16 PM
svolpone's Avatar
svolpone
just pull on the steering wheel and have someone hit the nut with a hammer.
Old Mar 17, 2014 | 03:54 PM
KO1960's Avatar
KO1960
I have a puller from HF, and it works fine.
Old Mar 17, 2014 | 04:24 PM
Becky_is_a_66's Avatar
Becky_is_a_66
I have a Harmonic balancer puller like the one in the link below; it has worked on all the steering wheels I have pulled off over the years. I have had it for so long though that I cannot recall the brand of the one I have.
http://www.summitracing.com/search/d...s?autoview=SKU
Old Mar 17, 2014 | 07:06 PM
crazed87bronco's Avatar
crazed87bronco
I have one that looks almost identical to the one Becky is a 66 posted a link to above. Mine is a craftsman brand I got it at sears acouple years ago. It worked for both my 64 and 71 steering wheels and my harmonic balancer.
Old Mar 17, 2014 | 08:04 PM
charliemccraney's Avatar
charliemccraney
I have a universal one like linked above and a Lisle steering wheel puller. Both work. The Lisle does fit the bolt spacing better, and made in USA.
Old Mar 17, 2014 | 10:01 PM
Macs1964F100's Avatar
Macs1964F100
I got a $9 hamonic balancer puller from bargin bin at AutoZone. None of the supplied bolts so you will need to get some that will thread in. I an sure someone on the site knows the size.
Old Dec 31, 2017 | 03:34 AM
benbuilder's Avatar
benbuilder
I did a search and came to this thread. I am pulling my 66 f100 steering wheel and my puller set does not have the proper thread for this wheel. Anyone know what it is?
Old Dec 31, 2017 | 09:24 AM
spurredon's Avatar
spurredon
I believe it's either 5/16-24 or 3/8-24. Easy enough to make one. Get a small piece of solid bar,1'x1/2 or so about 3 1/2 inches long, whatever you can find, drill two holes in it the width of the holes in the wheel for the bolts to go into and then drill and tap a hole in between the first two for your jack bolt. Kind of plain and simple but who dosen't like simple these days.
Old Dec 31, 2017 | 10:19 AM
Bert65's Avatar
Bert65
if you have HF close by, this kit will have every size
https://www.harborfreight.com/bolt-t...set-62620.html
Old Dec 31, 2017 | 10:44 AM
daveengelson's Avatar
daveengelson
Posting pic of puller similar to the links members posted, suggest using same/similar type pulley. 2 bolts screw into the treads in the steering wheel, the center bolt has a pointed shaft that sets into the steering shaft and one only need to turn the center bolt and the wheel comes right off. Strongly suggest one not use a pulley where arms are used go grasp the steering wheel from the back of the wheel while pressure is applied the the face?
Also an opportunity to make any repairs to the wheel if needed. Repair requires a mini rectangular file, and a container of A/B epoxy putty. Only mix enough to repair the crack keeping hands moist and remove any excess putty from wheel patterns; i.e., groves, etc., keeping in mind sanding excess epoxy putty is a major pain.
Old Dec 31, 2017 | 01:43 PM
benbuilder's Avatar
benbuilder
i believe it is 5/16 x 24.
Old Dec 31, 2017 | 06:39 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
350983-S .. Steering Wheel Nut ~ 5/8" -18 / Obsolete
1961/67 F100/250 & Econoline / 1963/68 F350/950.
Pic from 1964/72 truck parts catalog:
Old Dec 31, 2017 | 06:42 PM
benbuilder's Avatar
benbuilder
I am sure number dummy is correct on the nut holding the steering wheel down.
the 5/16 x 24 is the thread size for the steering wheel puller bolts
Old Dec 31, 2017 | 06:48 PM
NumberDummy
See 350983-S steering wheel nut in '64/72 parts catalog pic (below 3600 applications).
