Ringing noise
Old Apr 25, 2005 | 04:38 PM
DD1684's Avatar
DD1684
Ringing noise
2000 PSD automatic. When I drive it, sometimes I hear a ringing under the hood. It does it on and off. Anybody know what I'm talking about?
Old Apr 25, 2005 | 05:47 PM
Kwikkordead's Avatar
Kwikkordead
Not much to go on here. How about a loose AC clutch ring that is rattling around on the pulley?
Old Apr 26, 2005 | 01:57 PM
DD1684's Avatar
DD1684
Doesn't look like it.
Old Apr 26, 2005 | 02:36 PM
DD1684's Avatar
DD1684
I'll try being a bit more specific. It only happens when I hit the accelerator. It comes and fades. It's not very loud, but it's definitely a ringing sound. Something could be loose. It sounds similar to hitting a steel post with a hammer, only it goes on and off. Again, it's not very loud and it's under the hood. It does seem that the noise is either somewhere in the middle under the hood, or toward the driver's side. I've driven other PSDs and haven't heard this noise before. Definitely sounds like it's coming from something steel though (hence the ringing). Just in case, I checked for leaks, and there are none apparent. Checked the fluids too. All good. Didn't check the air filter and fuel filter though. Hope this will give you experts a better idea, because I'm no expert!
Old Apr 26, 2005 | 10:21 PM
Kwikkordead
UGH. Check your turbo for loose bearings and the intake wheel hitting the housing.
Old Apr 27, 2005 | 09:02 AM
DD1684's Avatar
DD1684
Thanks for the tips Kwikkordead!!! I'll do that right now.
Old Apr 27, 2005 | 10:16 AM
RobertJohn's Avatar
RobertJohn
My Dr. told me it's caused by high blood pressure !
I've actually picked up my cell phone and looked !
Oh well...enough...I just couldn't resist...
Old Jan 31, 2009 | 10:01 AM
f350xlt460's Avatar
f350xlt460
I have a similar noise in my wifes truck. Around 1600-1800 rpms (under load) not reving in neutral. Ive tried to pin point the noise with a stethascope (sp?) while wife powerbrakes the truck to make it make the noise but no luck. Truck is stock except for muffler delete and diablo tuner (mild setting). Seems to me that the truck is low on boost pressure but part of that I think is my boost gauge reading about 4 psi low. Ill try to get a video or sound clip on youtube sometime soon and would love to try to solve this annoying noise.
01 f250 auto 4x4 with about 115k
Old Jan 31, 2009 | 11:51 AM
Izzy351's Avatar
Izzy351
You sure you're not just hearing the turbo singing to you??
Old Jan 31, 2009 | 01:40 PM
f350xlt460's Avatar
f350xlt460
Definently not the lovely "singing" a turbo makes. After about 2000 rpms under load it is clearly the turbo singing. But 1600-1800 or so is a different noise all together. If the shifts bring the rpms back down through that rpm range ill hear the noise. Im afraid it has something to do with the turbo but from the drivers seat it sounds like its comming from the drivers side of the engine. Maybe through the intake?? Its so hard to diagnose since the engine has to be under a load at that rpm range.
Also, it seems that the boost will start to build as the noise goes away.
Old Jan 31, 2009 | 05:33 PM
Izzy351's Avatar
Izzy351
You could try building a boost leak detector, like this:
That would rule out an intake boost leak. Check the up-pipes for soot, too...
Old Feb 1, 2009 | 07:06 AM
f350xlt460's Avatar
f350xlt460
I bought one a while back and found out that one of the boots was leaking. I replaced them. Now there is no leakage at the boots or up-pipes.
BobbyB
Sep 26, 2011 10:17 AM
deadboy0
Mar 29, 2011 05:02 PM
fast70
Oct 13, 2010 10:53 PM
supercab78
Jan 22, 2006 07:39 PM
53choptop
Jul 6, 2004 01:47 PM
