lost spark?
Old Apr 26, 2005 | 12:14 PM
qwik88's Avatar
qwik88
the rotor does turn im gonna get a new cap and rotor today and a eec relay
Old Apr 26, 2005 | 01:11 PM
Silver Streak's Avatar
Silver Streak
Originally Posted by qwik88
i checked for spark at the wire and for power at the coil
At the coil wire or the plug wire? If you have no spark at the plug, but do have it at the coil the rotor is probably burned through to the distributor shaft.
Old Apr 26, 2005 | 10:41 PM
qwik88's Avatar
qwik88
at the plug wire there is no spark
Old Apr 26, 2005 | 11:57 PM
rhetor's Avatar
rhetor
cap and rotor should solve the problem...
if its getting power to the distributor, and the thing is spinning, it should be getting to the plugs.
Old Apr 27, 2005 | 01:45 AM
stractor's Avatar
stractor
I am making an assumption that your engine is an EFI engine and not a carbureted one. If so you have an TFI-4 system. Power for the coil comes from the EEC RELAY, so just because you have voltage on the coil doesn't mean it will run. You state you replaced the Module ?? Which one, the one on the distributor
( TFI MODULE ) and the coil. Did you remove the distributor to replace the module ????? If not --are you sure that you got all the connectors on the module seated in the mating connectors in the distributor???? The HALL EFFECT SWITCH (STATOR) in the distributor could be bad , it is the electronic version of points. Also one of the inputs to the TFI MODULE on the distributor comes from the starting system (starter solenoid on the diagram) and appears to supply power to the module when the engine is cranking only ( wire color Red/ Lt Blue), check for power when the engine is cranking. There is another input to the module for when the engine is running and the start input goes away. Aside from that there is not a great deal left. What remains are a lot of wire connectors.
stractor
Old Nov 14, 2005 | 08:57 PM
jjudd84's Avatar
jjudd84
Stractor, if the input to the TFI module is hooked up to the Starter solenoid (the Red/Lt Blue) wire that you mentioned then wouldnt it be getting power for as long as the ignition is on? You mentioned that it was only for the amount of time that the engine was cranking. The reason that I am asking is because I put EFI on my 78 Ford and I hooked that very wire that you are talking about directly up to the Solenoid. I have been having problems with the timing and such, perhaps I hooked that wire up incorrectly? Just curious what exactly you meant
Old Nov 14, 2005 | 10:36 PM
qwik88's Avatar
qwik88
i dont know exactly what your asking but i really dont rember anything about that truck it ended up getting junked a few months back and now i have a bronco with a new set of problems aka engine
FuzzyF150
Jul 1, 2016 11:15 AM
5speed50
Feb 15, 2016 04:36 PM
jonesg
Jun 8, 2015 06:08 AM
Bigal84088
Utah Chapter
Mar 21, 2011 07:02 PM
d4e2a0d
1978 - 1996 Big Bronco
Jan 18, 2010 11:59 PM
