Offroad & 4x4
ladder bars
Old Apr 25, 2005 | 08:25 PM
Momudder720's Avatar
Momudder720
None taken at all. I am just a man...
I'm just trying to devise a way to adapt my 3/4" heims to make the 4 link. What's usually used for the 4-link bars? I'm guessin that 1 1/2" .25 wall is both heavy AND heavy duty. I was thinkin maybe some 1 3/8" .180 wall would be heavy enough? Or should I step up bigger stuff, like 1 7/8" .180 wall?
And while I'm on the subject of hijacking the thread (sorry piperig), why don't I just use the search function? Hey Ivan, what stuff did you and Seth use for your ladder bars? If they can hold up to you two knuckleheads, they oughta last me at least a LITTLE longer...
Old Apr 25, 2005 | 08:43 PM
proeliator's Avatar
proeliator
I just used pipe for my ladder bars. Some guys use pipe for the 4-links but I think dom is the way to go.
Old Apr 25, 2005 | 09:53 PM
ivanribic's Avatar
ivanribic
I personally wouldn't expect the 1.5" O.D. .25" wall stuff to be heavy enough for a 4 link. There's a BIG difference between the force applied to the bars in a 4 link and the bars in a traction/ladder bar setup. What I was looking at for links was 2" OD DOM with a .5" wall. I may end up going to a 2.5" OD tubing. It's going to be expensive as all hell but I don't want to skimp here. I would not under any circumstances use a .180 wall here.
FWIW White Knight is using pipe for their links, not DOM but they also bend the hell out of them and seem to be replacing links fairly often. To my knowlege they haven't outright snapped a link. I'm unsure of the diameter that they're using.
Btw, my ladder bars are 1" ID schedule 80 pipe with a 3/16" wall.
Old Apr 26, 2005 | 07:20 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
The ladder bars I made for the 2WD are 1.25"x.125 DOM. I abuse the holy jebeezus out of them and they seem to hold up fine. Granted, they're only 21 inches long, but they are working. Keep in mind that these ladder bars ARE the axle locating links (besides the track bar) and keep the axle in place.
https://www.ford-trucks.com/user_gal...oid=72954&.jpg
https://www.ford-trucks.com/user_gal...oid=72956&.jpg
The bars I made of the monstertruck aren't exactly ladder bars, although they serve the same purpose....to eliminate forward/aft rotation of the axlehousing under severe torque loads. Like I mentioned earlier, I made these bars the length and angle I needed to match the rearward movement of the rear axle under suspension compression (banana leafs). I don't have any good pictures of this setup yet, but it's just a simple antiwrap bar setup. Oh, and I used 1.5" SCH 80 pipe for those with the same setup for rod ends as monsterbaby used. I went to "Big R" and bought two of the 3-point top links with the 1" thread and 3/4" hole. They were cheap and it was VERY easy to weld the threaded portion of the links into the pipe. Plus, they give you adjustability just by loosening the jamb nut and turning the pipe because one end is RH thread, the other is LH.
Cody
Old Apr 26, 2005 | 09:37 AM
mark a.'s Avatar
mark a.
Originally Posted by ivanribic
DOM is expensive but you only need a short length for the drag link. My drag link is 2 feet long exactly. At $13 a foot (.25 thick wall, 1.5" OD) it cost $26. If your steering box is outside the frame you might need 2.5 feet. It's not that much money but when you don't have it you don't have it. Tell your wife to let go of your wallet Nick!
Wow, I thought the guy at our local steel shop was trying to rob me when he said 12$ a foot. I had no idea it was really that expensive because their prices are always high there. Luckily I found a piece for free.
Old Apr 28, 2005 | 02:35 PM
piperig78's Avatar
piperig78
Do any of you guys have any close up pictures of how you mounted them to your rear axle. I have an idea how i am going to do the rest of them, I just dont know how to mount it on the rear axle.
Old Apr 29, 2005 | 09:34 AM
mark a.'s Avatar
mark a.
The back side has a piece of cut out pipe the size of the housing welded in to a radius cut into the piece that holds the 2 pieces of tubing it to locate the bar to the axle.
Old Apr 29, 2005 | 09:48 AM
Momudder720
Wow, Mark! Those are bling-tastic! I can't tell on the back there, are the welded up solid, or with bushings/heims?
Old Apr 29, 2005 | 10:00 AM
mark a.'s Avatar
mark a.
2 u bolts. There are more pictures in my gallery.
Old Apr 29, 2005 | 10:13 AM
Momudder720
You use pipe or tubing? That resembles 1 1/4" tubing...
Old Apr 30, 2005 | 07:45 AM
mark a.'s Avatar
mark a.
Not sure what there made out of. They came from a junk yard. I don't think it's tubing though, they're pretty heavy.
Old Apr 30, 2005 | 10:15 AM
monsterbaby's Avatar
monsterbaby
although mine aren't nearly as bling as marks (those look really good BTW) I used 2 pieces of quarter plate cut out to the axle and welded on the front side and also used a ubolt through them. You definatly want to use the ubolts I seen one guy who didn't and it snapped off (expecially with longer bars), and if your a real good welder it can actually tear the axle housing.
Old Apr 30, 2005 | 11:09 AM
  #28
dbhr's Avatar
dbhr
Do they need to be adjustable, or just bushings on each end? Another ?, could you run a single bar from the front spring hanger to the spring mount on top of the spring, would this help with axle wrap?
Old Apr 30, 2005 | 11:24 AM
  #29
monsterbaby
I suppose you could just bush the end, I prefer to have mine adjustable although I never mess with them since they are set but if you don't get everything just right then you are gonna have it pulling harder on one side were as with adj on hte front end if you are getting more hook on one side, and it trys to torque in one direction or the other you can adjust the bars to make it pull straight. I have seen the single bar on top of the leaves but have never tried it so can't give an opinion.
Old May 1, 2005 | 09:55 AM
  #30
dbhr's Avatar
dbhr
Thanks Monsterbaby for the reply. How is the engine coming along? Hope it is coming along well. Need to keep us posted.
