Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Homemade or Cheap OBD Reader
Old Apr 19, 2005 | 10:35 PM
DaveWW00's Avatar
DaveWW00
Anybody know how to build or where to buy a cheap obd I reader? I have seen obd II connectors and such that you can hook to your laptop or palm pilot which would be really nice and you can get all kinds of information besides the standard fault codes
Old Apr 19, 2005 | 11:03 PM
Rockledge's Avatar
Rockledge
If you just want to read the codes, that can be done with a simple jumper wire, even a paper clip will work, on EEC-IV (OBD-I) Fords. You just have to watch the CEL blink.
Pulling Ford EEC-IV Codes
As for hooking up an EEC-IV vehicle to a computer, I have no clue, but I'm sure there are things ought there, you might try your question in the Computer and Tuning Forum.
Old Apr 20, 2005 | 02:35 AM
V10man's Avatar
V10man
www.harborfreight.com has one for $40 Item # 46030-1VGA
Old Apr 20, 2005 | 03:14 AM
TigerDan's Avatar
TigerDan
Got mine at Kragen's for 35 bucks, I figure that's cheap enough for a digital code scanner. -TD
Old Apr 21, 2005 | 06:39 AM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
I got this one at a Kragens for $30. Click here .
Old Apr 21, 2005 | 07:46 AM
MBDiagMan's Avatar
MBDiagMan
As Rockledge said, on OBDI all you need is a paper clip. Get a Haynes manual for the truck and it will have very simple to follow instructions for doing this plus lots of other troubleshooting info.
Good luck,
Doc
Old Apr 23, 2005 | 07:18 AM
maa139's Avatar
maa139
Good luck,
Doc
There's also a stickey thread called 'technical information' in the ranger forum that has instructions to pull the codes....
Old Apr 23, 2005 | 10:07 AM
TigerDan's Avatar
TigerDan
Sure but for 30 bucks for a digital scanner, how can you go wrong? That's less than the cost of a tank of gas (ouch!) and eliminates having to count sweeps of the needle on a multimeter or other methods that contain a margin for error. For me, the less thinking I have to do, the better! If I hurt my brain just trying to figure out what the codes are, I just don't have enough left to figure out what to do with 'em after I've got 'em! (Ahh, such are the trials of old age and advanced CRS!) -TD
Old Apr 23, 2005 | 04:16 PM
MBDiagMan's Avatar
MBDiagMan
I guess I'm just too big of a cheap skate to spend $30 for something to replace something that is virtually free. I have no trouble counting the blinks of the light.
Have a great day,
Doc
Old Apr 24, 2005 | 10:09 AM
924x2150's Avatar
924x2150
There are OBD 1 systems out there that don't send signals to the Check engine light. My 92 F150 does, and all I need is any metal wire for the circuit. Unfortunately, my 91 Probe needs an analog voltmeter in the circuit to read code flashes.
To eliminate the need to run around looking for a jumper wire, determine which two wires need to be shorted to start the test, then you can mount a simple toggle switch in a convenient spot, run the switch wires to the two test wires and tap into each wire. Cover the splice with electrical tape or buy the fancy inline splicers that just pinch thru the wire. Whenever you need to check the codes, just flip the toggle switch and turn the ignition on.
At that point you only need to read the CEL flashes, or worst case scenario, a 20 dollar analog voltmeter placed across the positive battery terminal and the self test output pin on the EEC test connector.
I do not like OBD 1 fancy 40 dollar code readers, for one reason...they cost forty dollars.
Old Apr 25, 2005 | 08:17 PM
DaveWW00's Avatar
DaveWW00
I did it today using a wire in the STI and it worked pretty good. Definately dont need to buy a reader. It took me a time or two to figure out when it was starting and ending each code and the different types of codes. If figured it out though. The only code i got anyways was the one telling me the AC wasnt working which i already knew since the compressor locked up last year.
Old Apr 29, 2005 | 10:14 AM
da'Moose's Avatar
da'Moose
I paid $180 for mine and I can read any and all to this point, OBD-I, OBD-II, and older systems. It came with four cables to look at Ford, GM, Mopor, and imports. If I am to spend any money on a tool I would like it to work in as many cars and trucks as I can, I never know what will be sitting in my driveway next. I am a Ford man but, six months ago I lost my Chev, Suburban in a wreck and now I have a Volvo for the wife to drive…..
Da’Moose
Old Apr 29, 2005 | 01:00 PM
pfogle's Avatar
pfogle
You can use a $5 test light in place of the volt meter....
bashby
Nov 21, 2014 07:25 PM
Gmeanie
Nov 3, 2013 08:19 AM
talock
Aug 29, 2011 04:22 AM
Roushians
General Automotive Discussion
Dec 24, 2005 10:37 PM
jimbob21rc
Mar 10, 2005 04:28 PM
