I've asked this question before and also searched, but what make and year bedliner will fit in a 67-72 short bed?? ive heard maybe the 80's dodge. Any help would be appreciated because I am going to order one if I can get a definate answer on which one will work.
Get yourself a good inch wide 25 ft long tape measure. Bigbox store about $10.00, and measure some trucks. I think the swb Ford is about the same up to 96. A half inch wont make any difference as far as I know.
ok i have got one John i know about the measuring tape so no need there I have been measuring a number of trucks. I want a cover to go over top of my bed. I have not been able to find a newer model ford but are those beds the same.
do you know what model dodge liner that was you used in yours? i don't want to use a spray in liner because i want to cover up all the dents and the metal ive had to weld in the bottom
There is a Ford factory bedliner in my 70 shortbed parts truck (located in classifieds, very negotiable, hint!) it appears to be from 93-96 over the rail type, and cut back slightly at the rear. I have also used a modified toneau cover from the same later model as the width is correct. Hope this helps.
If anyone near Ohio needs the bedliner I will trade it for an AC compressor bracket for a 302, or?
The Doge liner I used was for a mid 80's truck. I got it at US 21 Camper Sales in Rock Hill, SC. Phone # 803-366-4161. They knew what fit when I rolled in there.
