Transmission needs help
Old Apr 18, 2005 | 09:57 PM
captnmike's Avatar
captnmike
I need to repair or replace my transmission in my 57, it has a stock 3 speed manual on the column I belive it's a T86. The case is worn and internal gears etc are worn or broke. I have a stock 272 setup any help on finding or replacing with different setup or fixing what I have.
Old Apr 19, 2005 | 10:09 AM
captnmike's Avatar
captnmike
I found a few of the gears now I need a T86 case
Old Apr 19, 2005 | 08:15 PM
barry's Avatar
barry
T 86 is a O/Drive tranny. Look at your case and post the I D markings. 3TAM should be your case markings.
Barry
50 F-1
Old Apr 19, 2005 | 10:04 PM
captnmike's Avatar
captnmike
The numbers on the case are AF-7006-D 21 and on the tag 73T
Old Apr 19, 2005 | 10:07 PM
captnmike's Avatar
captnmike
Forgot to mention the trans doesn't have overdrive so maybe I didn't identify it right.
Old Apr 20, 2005 | 06:39 AM
barry's Avatar
barry
I don't see that tag. Look on the case itself for casting numbers and letters. I suspect it to be a Ford 3 speed, but want to confirm. These casting s are moulded right into the case on either side.
Barry
Old Apr 20, 2005 | 09:50 AM
captnmike's Avatar
captnmike
The numbers on the case 73T:
AF-7006-D then a 21
I'd email you pictures of it but I'm a new user and can't
Old Apr 20, 2005 | 10:41 AM
55Bubba's Avatar
55Bubba
Mike, the standard ford 3 speed will work up as long as it came from a y block motor. I have an FE block motor that required an adapter plate to bolt the original ford 3 speed to it. I beleive it is the same for other non y block engines as well. You may want to check John Mummerts site for trans adapters for newer trannys. You can always fins an original either in the classifieds here or on ebay. with folks going "darkside" they are fairly plentiful
Hope this helps
Bubba
Old Apr 21, 2005 | 07:30 AM
captnmike's Avatar
captnmike
I'm new to this and was wondering what does darkside mean - with folks going "darkside" they are fairly plentiful
Old Apr 21, 2005 | 08:45 AM
Randy Jack's Avatar
Randy Jack
"Darksiders" are the custom and street rod folks. The bane of the resto guys. It's all just some friendly ribbing, but kinda fun.
Old Apr 21, 2005 | 11:07 AM
51ford fan's Avatar
51ford fan
Red face
Yeah, it really bothers me how people like Boyd Coddington can take a complete orginal and destroy it's heat and sole. I can understand a rusted body with no driveline or interior. But destroying a complete running orginal really hurts, yes it is the dark side.
Rod
Old Apr 22, 2005 | 03:26 AM
pcmenten's Avatar
pcmenten
AF-7006-D then a 21
I have a 3sp/od trans with a case that has that the sequence AF-7006- cast into it. It has the large, 10 spline input shaft. In other words, it's a truck transmission. I think that's a fairly common case.
Old Apr 23, 2005 | 07:58 AM
captnmike's Avatar
captnmike
Does reference show this transmission number
The front bearing retainer diameter is 4 13/16”
The main case casting number is C5AR 7006-
The date code appears to be 6 M 16
The identification tag reads RAN G 1 K024280
Tail housing casting number RF-C5TR-7A040-BBI
Old Apr 23, 2005 | 05:14 PM
barry's Avatar
barry
RAN-G is from a 1970 F-100 with a 240 and 131" wheel base. It's a regular Ford Light duty trans.
Barry
Old Apr 23, 2005 | 09:55 PM
captnmike's Avatar
captnmike
Thanks for the info
Le Juggernaught
Jun 2, 2016 08:54 PM
Buckindamnbronco
1978 - 1996 Big Bronco
Feb 26, 2016 10:37 PM
2002exPSD
Feb 18, 2016 04:47 PM
Bassindude
Sep 25, 2015 05:01 PM
rosa70
Aug 23, 2006 06:24 PM
