Transmission identity help
Old May 31, 2016 | 04:55 PM
Le Juggernaught's Avatar
Le Juggernaught
I have a 1990 f250 2wd 7.5L with 133 WB. My ID tag is worn off and I need to know if anyone knows the stock model number of the automatic transmission put in these trucks back then if they could let me know so i can order a new driveshaft.
Old May 31, 2016 | 04:59 PM
whomrig's Avatar
whomrig
try this:
FordEtis home page
enter your vin, if it doesn't work, pm me your vin I will try it
Old May 31, 2016 | 05:08 PM
85e150's Avatar
85e150
3 speed or 4 speed OD?
Check that pan. Also, I am moving this to the proper forum for your truck.
https://www.ford-trucks.com/user_gal...d=169485&.jpg=
Old May 31, 2016 | 05:23 PM
Le Juggernaught
Originally Posted by whomrig
try this:
FordEtis home page
1FTHF25G4LPA18239
Old May 31, 2016 | 08:27 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
it should be an E4OD.being a 460 truck this is the only option if you see an OD cancel switch.
though it's possible a C6 could of still be optionally ordered.so if you don't have an OD cancel switch and all you feel is 2 shifts when taking off in D then it's the old dinosaur.
trans code on the door jam sticker for E4OD = E
when you look at an e4 pan,you'll see a crap load of pan bolts and METRIC stamped on it.
trans code for c6 is i think = G?
Old Jun 2, 2016 | 11:50 AM
whomrig's Avatar
whomrig
Originally Posted by Le Juggernaught
look like the etis page doesn't like this vin#
maybe go to your ford dealer, the parts guy can pull up info on your rig perhaps
Old Jun 2, 2016 | 01:32 PM
White 97 xlt's Avatar
White 97 xlt
14 pan bolts = C6, 20 pan bolts = E4OD
Old Jun 2, 2016 | 08:54 PM
Encho's Avatar
Encho
The Southernmost Mod
^ Easiest way to tell 100%
paulq
Nov 23, 2009 09:05 AM
Tommy_Mills
Jan 19, 2009 05:28 PM
rutang
Jan 24, 2008 12:03 PM
gfinch1050
Jan 15, 2007 12:37 AM
old henry
Sep 9, 2004 05:12 PM
