tricumulator valve
Apr 17, 2005 | 12:18 PM
tricumulator valve
do you have to remove the valve body in the trans to install the sonnax tricumulator valve and springs?
Apr 17, 2005 | 12:44 PM
Check out my site, its in my signature, look under tech. Its held up with 8mm bolts and 2 10mm nuts.
Apr 17, 2005 | 12:45 PM
Just the front accumulator valve body (sits across the entire front part, side to side, of the transmission), held by two (10mm) nuts and eleven (8mm) bolts. Allow Valve body to drain on one side before removal.
Apr 17, 2005 | 12:59 PM
is there a gasket that goes between the valve body and trans?
Apr 17, 2005 | 01:08 PM
Quote:
no, its a machined fit. you will need an inch pound torque wrench to reinstall it though.tighten too 80-100 inch pounds if i remember correctly
Apr 17, 2005 | 01:25 PM
Dozer, most kits you purchase will come with instructions. It is a very easy install, even for those who are uneasy about working on their tranny.
Apr 17, 2005 | 03:38 PM
it is an easy mod. i have noticed that no one has yet to mention how messy it is. it will make a mess.
Apr 17, 2005 | 07:56 PM
hey, guys thanks alot. this forum is the best. i am going to attempt the install this weekend. had a pond dug last fall still cleaning up that mess.
Apr 17, 2005 | 08:14 PM
Quote:
There are some who enjoy transmission fluid all over their arms
.... or all over their driveway
Apr 17, 2005 | 10:10 PM
Old clothes, big drip pan, lots of rags. The mess is temporary, the shifting improvement lasts a long time.
