Trailer Lighting problem
Old Apr 16, 2005 | 10:04 PM
Chips2000's Avatar
Chips2000
Hooked up my trailer today and there were no lights. The brake controller is indicating it is connected, but no running, brake and turn lights. I do not have a manual, but I was told to check fuse #6, but it is ok. Is there another set of fuse for the trailer wiring?
Thanks
Old Apr 16, 2005 | 10:16 PM
touchofgrey's Avatar
touchofgrey
You haven't mentioned your trucks year; but.....On a 99 1/2 to 2003.....the fuse is number 13 under the dash. Rated at 20 amps.
Old Apr 16, 2005 | 10:19 PM
barebackjake's Avatar
barebackjake
theres a fuse under the hood for the trailer lamp relay, cant remember which one it is at the moment.....the fuse is inder the hood.....ill grab the book and look
Old Apr 16, 2005 | 10:22 PM
barebackjake
#4 under the hood is the marker lamp fuse. the relay is one of the relays in the 2 relay box. should be the one thats on the same side as the rest of the relays in the other box
Old Apr 16, 2005 | 10:24 PM
barebackjake
BTW the ## i gave you were for a OBS truck.....
Old Apr 16, 2005 | 10:50 PM
Chips2000's Avatar
Chips2000
99 PSD...I guess that would help! I don't think it is a 991/2.
Thanks Again
Old Apr 16, 2005 | 11:00 PM
touchofgrey
That number may still apply. Check it out, and let us know. So we can continue to help if need be.
Old Apr 17, 2005 | 09:55 AM
Chips2000's Avatar
Chips2000
Checked fuse #6 and it is good, but fuse #13 under the hood is blown. It shows visually and with a VOM. Thanks, you guys just saved me a trip to the repair shop and more than a bit of change!
Thanks Again,
Chips2000
P.S. some time ago I went to buy a Clymers (had one for my '93 non-turboed 7.3 F-250) and could not find one. Where can I get a good manual for my '99 PSD F-250, if one is available?
Old Apr 17, 2005 | 11:48 AM
Chips2000's Avatar
Chips2000
Make that #4 was blown under the hood, not #13.
Old Apr 17, 2005 | 11:57 AM
Chips2000's Avatar
Chips2000
OK, the marker lights now work, but not the brake and signal lights. Could it be a relay? I checked voltage at the flat electrical trailer that is stored under the bumper, and it has no voltage except for the marker lights.
Old Apr 17, 2005 | 01:40 PM
touchofgrey
Under the Hood:
#1 & #3 are your right and left tow trailer stop and turn signals
#4 = trailer tow backup lamps, trailer tow park lamps
#8 = trailer tow electronic brake illumination, Park lamps trailer tow park lamp relay coil.
#16 = trailer tow battery charge
#28 = trailer tow electronic brake controller
#38 = trailer tow backup lamp relay
#39 = trailer tow battery charge relay
That's all I can find.
Old Apr 17, 2005 | 02:14 PM
Chips2000's Avatar
Chips2000
That did it, both #1 & #3 were blown. I will take note of all the numbers you gave me since I do not have a manual. Thanks for all the help.
Chips2000
Old Apr 17, 2005 | 02:26 PM
touchofgrey
chip.....get on ebay.....you'll find owner's manuals for almost every year there.
Old Apr 17, 2005 | 03:14 PM
Chips2000's Avatar
Chips2000
Thanks....Again!
Old Apr 17, 2005 | 09:20 PM
touchofgrey
Chips.....you still may have a problem. Something shorted enough to sink over 7 amps. I guess you would know if anyone shorted the system out. If not, I'd be looking at the points where the wiring terminates in the truck and the trailer. In the back of connector blocks.....that sort of thing.....also open insulation on the pigtail of the trailer.
