302 94" build up
Old Apr 16, 2005 | 07:47 PM
gergorio25's Avatar
gergorio25
302 94" build up
I have a 1994 F-150 302 V8 EFI and i want to stoke it out. What would i have to do to the efi ( if nething) for the stroke and what other modifications would be a good choice?
Old Apr 16, 2005 | 09:48 PM
Ford Truck Racer's Avatar
Ford Truck Racer
For stroking you will need to reprogram the computer or have a chip made. Cam, exhuast, and ignition are good upgrades along with better breathing heads. Here the 331 stroker kit seems to work the best over the 347 as far as longevity goes, 347 more power.
Old Apr 18, 2005 | 10:04 AM
Kemicalburns's Avatar
Kemicalburns
is your motor mass air already? best way to tell is the intake tubes will run from throttlebody int a 2 to1 tube that has a sensor right before filter box. this will determine if you can run a stroker or not
Old Apr 22, 2005 | 08:30 PM
gergorio25's Avatar
gergorio25
YEs my 302 is MAF. Can i just modify my existing heads or should i buy different ones?
Old Apr 22, 2005 | 09:04 PM
jesse1385's Avatar
jesse1385
Don't stroke your 302. Just simply get a 351W and be done with it and save alot of money. Stoked engines dont last near as long either, expecially the 347.
roadrash63
Aug 7, 2009 04:05 AM
Dean88
13
May 28, 2008 01:19 PM
stangfan78
Engine Swaps
Dec 17, 2006 09:57 AM
scottie2hottie
Oct 25, 2004 06:21 PM
the lloyd wards
Mar 7, 2003 05:50 PM
