fuel pump lobe? efi...
Old Aug 3, 2009 | 04:41 PM
roadrash63's Avatar
roadrash63
hi
i would like to know what i have to do to put a mech. pump
on an efi engine, i want to remove the efi.(302)
no i dont think efi is great...
is the pump lobe there or what needs to be done
Ty
RR63
Old Aug 3, 2009 | 08:55 PM
Conanski's Avatar
Conanski
This is a Ford motor... there ain't no fuel pump lobe. (insert **** on Chevy logo here)
All you need... if your motor doesn't already have it, is an escentric.. a little disk that bolts to the outside of the cam timing gear, and of course an old style timing cover with the fuel pump boss in it.
Old Aug 4, 2009 | 04:42 PM
roadrash63's Avatar
roadrash63
ok !
thanks for the info conanski
what about removing the elect fuel pump?
can I use the efi fuel tank?
and what about the sending unit?
i want to remove as many sensors etc. as possible
but still walk into a auto parts store and get a ford part...
ty
RR63
Old Aug 4, 2009 | 10:03 PM
tonfro's Avatar
tonfro
you might also need a longer pin that lines the cam up with the timing gear.
on my efi, the pin was not long enough to go thru the timing gear and the fuel pump eccentric.
i replaced my timing gear and chain and it came with a longer pin.
if you go junking for the timing cover and eccentric, make sure to get that pin.
you probably are going to need a different distributor because if yours is on a computer it wont work right at all.
my suggestion, go duraspark2 distributor from an 85 mustang gt, 5.0 liter with a manual tranny, that way you get the steel gear you MUST use or you will trash the cam gear or the motor
gt
gt
Old Aug 5, 2009 | 05:38 AM
lew52's Avatar
lew52
Not sure what cam is in the truck , if its a roller cam you will need steel , if its flat tappet cast cam you need a cast gear....Lew
Old Aug 5, 2009 | 09:09 AM
Conanski's Avatar
Conanski
RR63
Well actually that truck will have 2 pumps, a low pressure in-tank and a high presure pump and switching resovoir on the frame. You could simply eliminate the frame mounted bits and plumb the in-tank pump directly to the carb. Problem solved.
Old Aug 7, 2009 | 04:05 AM
roadrash63's Avatar
roadrash63
cool
thanks
for the info
ill start next summer ...
this one is about done and i dont have a garage
1981 convert
Feb 21, 2016 02:06 PM
POLARISrider500
Feb 4, 2016 05:52 AM
thatguy71
Mar 5, 2014 05:35 PM
yomow
1978 - 1996 Big Bronco
Feb 12, 2010 10:12 AM
WWB F250
Jul 5, 2006 08:00 AM
