coil problems
Old Apr 16, 2005 | 06:31 PM
larry65's Avatar
larry65
coil problems
Hi I posted this in the 61-66 forum but thought I would try it here also.I have 65 f-100 with a 1986 300 in it.I only have about 100 miles on it and I have gone thru 3 coils.They keep getting hot and failing it has electronic distributor I was wondering if A ballest resister would maybe help this problem TKS for any help at all!!!
Old Apr 16, 2005 | 06:32 PM
larry65's Avatar
larry65
Sorry about that I meant 1000 miles
Old Apr 16, 2005 | 09:17 PM
924x2150's Avatar
924x2150
It is an 86 engine 300, that is all we are sure of on this end. Did the entire EECIII ECA, harness, and distributor stay with the 86 engine or are you mix and matching?
Post the history of your build up.
Also, what is the symptom on the three blown coils, any opens circuits?
Just looking at the Haynes manual...Duraspark II and III systems both use a ballast resistor between the ignition module and battery side of the coil, and there is a few good pages of troubleshooting tips for both in the Haynes manual.
Old Apr 17, 2005 | 04:34 AM
larry65's Avatar
larry65
Ok thanks yes it is a duraspark two system that came with it in 1986.All I did was hook up the wiring harness the way the instructions said with the coil wire to the coil and dist.wire to the other side.All the original duraspark wiring was used. TKS
Old Apr 17, 2005 | 05:17 AM
924x2150's Avatar
924x2150
Haynes manual specs on Duraspark II;
Coil primary resistance:0.8 to 1.6 ohms
Coil secondary resistance:7700 to 10900 ohms
ballast resistor: 0.8 to 1.6 ohms
coil voltage from dizzy base(ground) to BAT terminal: 6 to 8 voltsDC
Old Apr 17, 2005 | 10:57 AM
5_labsownus's Avatar
5_labsownus
The older trucks did not have the resistor and DS II did and I have a truck with DS III OEM and if has the resistor and I have seen many DS III with out them! So use an aftermarket soil rof use without a resistor or install one the line!
Old Apr 17, 2005 | 10:57 PM
cdherman's Avatar
cdherman
Just to set the record straight, labsownus is correct that the older trucks did not have a *resistor* -- but the did have a resistor *wire* which functioned in the same manner. The bit of wire (historically pink and a little "thicker" than usual) from the ignition switch to the firewall, was actually a resistor. You need to bypass it for use with newer coils that are designed for 12v.
Old Apr 18, 2005 | 03:02 PM
wtroger's Avatar
wtroger
if you use a standard tube looking coil you need the resistor if you use the TFI open frame coil you do not need the resistor. Which is what I did on my 1984 it had TFI on it And I went back to duraspark II and used the TFI coil works perfect truck runs better that ever.
Old Apr 20, 2005 | 06:38 AM
larry65's Avatar
larry65
TKS guys for the replys I put another accel tube type coil on for a duraspark electronic ignition and checked for voltage when running and I had 11.76v. on the + side and 5.86 on the dist side.with the on (truck not running) for about 5 minutes the coil again got real hot.Almost to the degree of not being able to touch it for more then a few seconds.SORRY about the delay of getting back to you all but being a truck driver I am gone for 5-6 days at a time.TKS again for all your help.Hope one of you also had this problem and knows of a fix.
rjohnson_15
Dec 20, 2012 04:49 PM
jazzmaffy
Mar 31, 2010 10:44 AM
rick-65
Sep 27, 2007 10:52 PM
mtpcage
Electrical Systems/Wiring
May 7, 2006 09:06 PM
