key switch question
Old Dec 20, 2012 | 03:13 PM
rjohnson_15's Avatar
rjohnson_15
key switch question
I have a 65 f100 with a 5.0 msd distributor and coil. It's not getting the correct amount of volts to the coil to start the motor. When i hook the coil up to the battery it starts fine what is my problem, my key switch not putting out 12 volts? how do i fix this with out changing the switch? thanks
Old Dec 20, 2012 | 03:46 PM
DPhillips's Avatar
DPhillips
There's a pink resistor wire coming out of the ignition switch that drops the voltage to the distributor to 8-9 volts. Bypass it and you'll get a full 12 volts to the distributor. The wire was needed in the days of points to prevent them from burning up prematurely. If I remember correctly, the MSD distributor requires a full 12 volts.
Old Dec 20, 2012 | 03:57 PM
rjohnson_15
ok thanks! what would be the best way to bypass it?
Old Dec 20, 2012 | 04:49 PM
Shadowrider123's Avatar
Shadowrider123
I have a one wire HEI distributer to install. Im guessing that I will need a full 12v also.
Flecker
Nov 25, 2015 06:05 PM
Jeff K
31
Oct 21, 2013 02:49 PM
puroford
Jul 5, 2011 09:04 AM
Norm Spaulding
15
Mar 10, 2008 07:23 PM
nyfireman
Dec 14, 2005 09:03 PM
