1356 slip yoke bushing
Old Apr 14, 2005 | 01:02 PM
OX2's Avatar
OX2
I have a 95 F250 4WD and the output (slip yoke) seal on my 1356 is leaking. Got a new seal from ford, but the slip yoke seems pretty loose when I just slip the yoke into the ext housing (with housing OFF the TC). I realize most of the centering for the yoke should be done with the splines, but I'm wondering what the clearance should be between the yoke and the brass tube bushing inside the taillshaft housing?? My Ford parst guy claims that tailshaft is only 34$ (I don't believe it either), so if thats true, I might just go and replace it if it really needs it (if someone tells me there should be almost NO play)
Thanks
OX
Old Apr 26, 2005 | 09:02 AM
ktp744's Avatar
ktp744
I have the same situation with my truck and I am told that is a dealer item and the dealer only sells the complete extension housing for $300+.
Old Apr 26, 2005 | 09:13 AM
OX2's Avatar
OX2
I found the sleeve, onyl 14$. Try national drivetrain 800-507-4327, item # 1356127001 (better give them your TC tag to be sure it's the same part). Presses in and out easily. My old sleeve was not as worn as I thought as play between slip yoke and bushing was not that much different with new bushing.
Old Apr 29, 2005 | 01:18 AM
ktp744's Avatar
ktp744
Thanks for the info OX2. I'll check them out.
Rusty_S
Sep 15, 2015 09:54 PM
4wheelmax
Jul 31, 2013 07:35 PM
Ford4Life7.3
Aug 5, 2012 09:15 PM
RC Dan
Aug 25, 2008 06:23 PM
rockcrawl
Oct 27, 2003 09:55 PM
