Bronco II Ford Bronco II
86 B2 won't start
Old Apr 14, 2005 | 12:00 PM
LeHonolulu's Avatar
LeHonolulu
86 B2 won't start
MY 86 B2 2.9 w/AT won't start w/the key. I can jump the starter relay and it fires right up and runs great. Turn the key and NOTHING but the idiot lights.
I've replaced starter relay, neutral safety switch, ignition switch (on steering column), distributor mounted TFI, ignition coil, battery and cables. What's left? I am going to install a remote starter switch next if I've replaced all that I can w/out rebuilding the entire electrical system. So will someone tell me what I am missing?????????? Thanks.
Old Apr 14, 2005 | 03:11 PM
mrshorty's Avatar
mrshorty
Sounds like the start position in the ignition switch has failed, or a broken wire in that circuit. Do you have a wiring diagram to diagnose from?
Old Apr 14, 2005 | 06:15 PM
LeHonolulu's Avatar
LeHonolulu
Thanks for your reply,
By "ignition switch are you referring to the one I replaced (which is held by two screws to the steering column) or where the key is inserted? Yes to the wiring diagram.
Old Apr 14, 2005 | 06:17 PM
LeHonolulu's Avatar
LeHonolulu
I also checked for continuity of the three fusible links that are connected to the starter relay. All are ok.
Old Apr 14, 2005 | 07:15 PM
Ken00's Avatar
Ken00
He means the switch, the lock cylinder is were you put the key.
A good test is to see if you have 12v at the little wire at the starter solenoid, it activates the starter solenoid, when the key is turn to the start position, no 12v bad wiring or switch.
vfrf2
Apr 25, 2014 12:48 PM
1FastGambler
17
May 15, 2011 12:40 PM
cljohnson
Aug 9, 2010 11:57 AM
leonardschoelkopf
Aug 11, 2004 01:18 PM
Mach73
Jul 11, 2004 05:08 PM
