Won't crank - solenoid buzzes-strange elec issues
78 f-250
Symptoms that all started yesterday:
What is causing this problem?
Is it the ignition/key switch?
I'm at my witts end with this! Good advice is greatly appreciated!!
- Will not crank over at all
- Starter Solenoid buzzes
- horn "briefly" honked by itself a couple times
- Stereo comes on then right back off (key in run & in accy position)
- Starter was bad - replaced
- New Starter Solenoid
- One wire alternator - 170A from JBG
- Mark VIII fan - bought wiring kit w/tem switches (works great)
New battery cables, ignition switch, starter & two solenoids... Still have the same issues...
Battery had 11.8 volts, charged back up nicely to 12.6... Battery is less than 1 year old.
Figured it had to be the battery since that was all that was left... Swapped in the battery from my work truck for a test & she fired right up!!!
The thing that had me thinking it wasn't the battery is because I tried HD jumper cables off of my diesel and nothing changed.
I've seen batteries do some strange things before in my bassboat, but this is a new one on me. I thought the battery might be the problem after the solenoid didn't fix the problem & since jumping the posts on the solenoid wouldn't crank her over.
Stupid battery shows over 12 volts & still doesn't have enough "UMPH" to turn over a starter motor.
Lesson learned... battery voltage is NOT an indicator of true battery condition.
I hope that this post will save someone a lot of trouble. i.e. - if you have these symptoms... try swapping in another battery from a running vehicle before spending any money on new parts.
I'm not too concerned about 'ol Blue having all these new parts since I'll have my new TMI 400 in a few more weeks & the ZF-5 to go with it...
