302 HO timing
Old Nov 5, 2000 | 02:02 PM
SadButTrue's Avatar
SadButTrue
302 HO timing
I have a 84 F150 4x4 with a 302 ho out of an 84 mustang. We got the engone from a wrecked truck. I cant get the engine timed right, it constantly misses. It ran fine in the other truck, but when we swapped it to mine, it idled very high. My truck orginally had a 6 in it. We switched the wiring harnesses, thinking that the wiring between the 6 and 8 might bhe different, but that did not help the idling probelm. We rebuilt the carb, which fixed the high idle, but now it always misses. We put a new cap and rotor on it,which did not fix the problem. What could be casuing thius? The truck has open headers right now until we can get it to run smooth enought toget to the muffler shop. Could not enough backpressuer cause this? Thanks
Old Nov 5, 2000 | 03:15 PM
bgodkin's Avatar
bgodkin
302 HO timing
The lack of back pressure is possible. Try getting some cheap header mufflers just to get it to the muffler shop with. It seems funny that it ran fine in the other truck but not in yours. Is there anyway you can use the exhaust form the other truck to test and see if that is it? Just a thought. How about the ignition module? did you pull all the ignition parts from the last truck? the mustatngs use a different ignition box than the truck engines. Hope this helps. I had a 88 HO 302 from a mustang in a 78 shortbed for a while. The one thing I did learn is that Ford went to external balancing about 85 and it shook like mad at idle. I got the right flywheel and harmonic balancer for it and it ran like a champ.
Brad Godkin
1986 F350 CC/SRW
6.9liter/C6
Old Nov 5, 2000 | 05:08 PM
SadButTrue's Avatar
SadButTrue
302 HO timing
All the ignition parts are for a mustang.
Old Nov 5, 2000 | 06:46 PM
bgodkin's Avatar
bgodkin
302 HO timing
could just be the back pressure then. Just a thought
Brad Godkin
1986 F350 CC/SRW
6.9liter/C6
Old Nov 7, 2000 | 12:53 PM
dre's Avatar
dre
302 HO timing
The 302 HO is not timed like the standard 302.
you need to use the 351W. timing order.
Old Nov 8, 2000 | 02:17 PM
bwana's Avatar
bwana
302 HO timing
new member was right about difference. the wiring pattern is different 302HO = 351W
Old Nov 8, 2000 | 03:05 PM
bgodkin's Avatar
bgodkin
302 HO timing
Good catch. I forgot all about that.
Brad Godkin
1986 F350 CC/SRW
6.9liter/C6
Old Nov 10, 2000 | 08:45 PM
tbob's Avatar
tbob
302 HO timing
Did it miss before you rebuilt the carb? if not, then I would be tempted to check out the carb and all it's connections before going elsewhere. Often, when you create a new problem while trying to repair another, go back to the last thing you worked on before the problem raised it's head. That't the most logical place for the problem to be. If it did miss before you rebuilt the carb, then this may not apply, but I hoped it would help. Tbob.
Old Nov 11, 2000 | 08:07 AM
reroy's Avatar
reroy
302 HO timing
Peavey1986
Engine Swaps
Jun 8, 2015 08:40 PM
gopher2
Jun 1, 2014 09:11 AM
muddyford911
17
May 29, 2009 12:39 AM
mvvette97
Sep 19, 2007 02:07 PM
rooter
Oct 31, 2004 06:11 PM
