Stiff clutch
Stiff clutch
I know its been discussed before, but has anyone found a way to get a softer clutch ? My 57, 223 with 4 spd has the darn stiffest clutch , its hard to drive in traffic. I tried my local Center Force retailer . they said they couldnt help my situation. I have a 11 in. clutch and pressure plate. Has anyone out there had this problem ?? Roy.
Clutch
Think I just answered my own question asked previously. The bolt pattern for a 10in plate IS different than a 11 in. Should have known that. I think my biggest problem is that I just have too much clutch. Considering getting rid of this HD 11in and going to a 10in. My overhaul manual (57) indicates that truck modelsF-100, 6cyc doesnt use a 11 in clutch, suppose to be a 10 in. The 11in is used when the 500-600 p-350 400 and 500 come in. Even the P-350 6cyc uses 10.5 in clutch. The f-100 and F-250 8 cyc uses a 10-5 in. So ---- I'm going back to a stock 10 in. I will have to change the flywheel, but I have one. When I get the thing in I will let the word out. Thanks Roy
Stiff clutch
Yea Rod I'm diffenently going to put a smaller disc in. I think that will take care of a lot of my problems. A side note, I'm also going to install a 3.25 rear end. Gotta get rid of this 4.11. If I do these two things my truck will almost be finished. I'm going to be awol for a few months, going north, back in Oct. See ya then. Roy
