T98 4 spd shifter
Old Apr 11, 2005 | 06:36 PM
murphy's Avatar
murphy
T98 4 spd shifter
Hello alll. Does any body have an OEM 4 speed shifter lever for the T98 , for sale ?
Thank you
Old Apr 11, 2005 | 06:40 PM
Madathlon's Avatar
Madathlon
What happened to ur lever?
Old Apr 11, 2005 | 08:42 PM
murphy's Avatar
murphy
I've got a really ugly, apparently homemade lever.
Old Apr 11, 2005 | 08:48 PM
Madathlon's Avatar
Madathlon
The lever is part of the top of the tranny.. I have a T98 in mine and had to heat it up so it wouldnt be a knunkle busted anymore.. I do believe a T19 might also fit
Old Apr 11, 2005 | 08:54 PM
286merc's Avatar
286merc
Where are you? Ive a few T98's Ive tossed off in the woods, too heavy to take to the dump.
murphy's Avatar
murphy
thank you very much
Old Apr 11, 2005 | 08:56 PM
murphy's Avatar
murphy
Southern California, Merc. I dont know too much about the mechanics of the T98, is it possible to remove just the lever, or is it part of a much larger assembly ?
Old Apr 11, 2005 | 09:00 PM
Madathlon's Avatar
Madathlon
From What I seen on mine.. its part of the top plate.. it could be removed, But putting it back togather not going to be easy.. I think the bottem levers are welded on from what mine looked like when I rebuilt it...
Old Apr 11, 2005 | 09:04 PM
reamer's Avatar
reamer
Hmmm, I need a complete T-98 myself. don't like the meat grinder in there now!
Old Apr 11, 2005 | 09:13 PM
Madathlon's Avatar
Madathlon
Well Reamer, I love to find something else that would just bolt in instead of the T98.. 1-2 is non syncro and 99.99999 of the time its a 2nd gear start which make it a 3 speed.. the 98 1st is way to low to use to start with unless your towing one hell of a load.. the Range is 1st 6.40,2nd 3.09,3rd 1.69,4th 1.00... Id love to find something with a 5th or even a 6th overdrive.... Id give this T98 away if I could find something to work...
Old Apr 11, 2005 | 09:43 PM
My58Ford's Avatar
My58Ford
I think you can adapt a Mustang 5-speed tranny to the y block bell housing.
In fact I'm pretty sure John Mummert sells the reworked bell housing for it.
It's been awhile since I've looked at his website.
Old Apr 11, 2005 | 09:49 PM
Madathlon's Avatar
Madathlon
But I have a 223.. a 6 banger.. not a Y block
Old Apr 11, 2005 | 09:54 PM
My58Ford's Avatar
My58Ford
If I'm not mistaken, I think the bell housings are the same for 223 & y block.
I'm not 100% sure though, you'd have to check into it.
Old Apr 11, 2005 | 10:05 PM
Madathlon's Avatar
Madathlon
ok.. Does this John have a web site?
Old Apr 11, 2005 | 10:12 PM
57_Fordguy's Avatar
57_Fordguy
www.ford-y-block.com
