T98 4 spd shifter
Old Apr 14, 2005 | 05:48 AM
  #31
FOWL1's Avatar
FOWL1
Murphy, 286meac said he has a couple in the woods. Maybe he could thake the shifter out of one and send it to you. It can't cast that much to ship just the shifter. I would check in local junk yards also. I was walking through one around me and way in the back, there it was , a '65 F-250. I know it had to have the T-98. They used these things for years. They even were used in cranes to run the cables up and down. Keep trying, you'll find one.
Old Apr 14, 2005 | 07:02 AM
  #32
reamer's Avatar
reamer
Remember, the T-98 that fits a '48-52' with a 239 is a specific T-98. nat all 98's will fit.
The 98 I need has to have the rear mounting arms turn and face forward. This is because the 98 is a little longer than the un-sync tranny.
With the rear mounts turning to the fronn, it fits in the crossmember.
Old Apr 14, 2005 | 07:57 AM
  #33
Madathlon's Avatar
Madathlon
??? My T98 has nothing under it at all.. its mounted to the bell housing and thats it..
Old Apr 14, 2005 | 06:33 PM
  #34
reamer's Avatar
reamer
That would be the wrong type for my '48 F-5
Old Apr 14, 2005 | 10:35 PM
  #35
My58Ford's Avatar
My58Ford
Madathlon,
You mean to tell us the crossmember that supports your tranny is gone???
Man I hope it does'nt fall out!!!
Old Apr 14, 2005 | 10:37 PM
  #36
Madathlon's Avatar
Madathlon
I dont think there was ever one there in the first place.. But every thing nice and tight..
Old Apr 14, 2005 | 10:45 PM
  #37
My58Ford's Avatar
My58Ford
Oh yes, trust me, there was one there at one time!
If yours is gone now, the only thing holding it all in place are the two front motor mounts,...and the driveshaft.
I'd be a little leary if it was me!
Are you sure you're correct?
The bellhousing has two ears on it that bolt to a crossmember, that's your tranny support.
Are you sure it's not there?
Old Apr 14, 2005 | 11:07 PM
  #38
Madathlon's Avatar
Madathlon
What I see under the truck it 2 front engine mounts, 2 rear engine mounts, Bell housing, and then a tranny hanging off the bell housing.. And it has 4 bolts holding it there ..
Old Apr 15, 2005 | 06:02 AM
  #39
FOWL1's Avatar
FOWL1
The cross member is not one that you would typically think is a cross member. The bell housing supports the motor as well as the tranny. to remove the tranny and bell housing, you need to jack up the motor and support it while the bell housing is off. The tranny has 4 bolts that hold it to the bell housing and there is not a cross member per say "under" the tranny. It's under the bell housing.
Old Jun 16, 2005 | 04:06 PM
  #40
bluestang65's Avatar
bluestang65
Mustang transmissions are far too light duty for use in a pick-up. While I currently run one in my old Mustang, I have seen the inside of this transmission (and rebuilt it when it failed my Mustang) and it is far too flimsy for Truck use. T5s were designed to last a 200 hp, 3000lb Mustang about 100,000 miles. Sorry to dig up an old post... Looking for T98 info.
Old Jun 16, 2005 | 07:16 PM
  #41
Christopher2's Avatar
Christopher2
Veteran: Navy
I have a T98 with a Chelsea PTO
Old Jun 18, 2005 | 08:21 AM
  #42
57_ford's Avatar
57_ford
This T98s the cap unscrews and the shifter comes rite out. Just watch the pin so that it doesnt fall into the trans. The trans is suported by the rear motor mounts in front of the trans.
Old Jun 18, 2005 | 08:53 AM
  #43
My58Ford's Avatar
My58Ford
Gee...we talked about eveything but getting Murphey a shifter.
Did you ever find one Murphey?
I have an extra nice one if you're still looking.
I have a nice white shift **** if you still need one of those too!
Old Jun 19, 2005 | 01:00 PM
  #44
murphy's Avatar
murphy
Thanks 58, I recently found a shifter with the white ****.
Martin Torres
Jun 19, 2017 08:59 AM
66crawler
Feb 22, 2016 04:24 PM
38 coupe
13
Oct 1, 2015 08:28 PM
billest
Oct 24, 2013 08:28 PM
contento
Mar 21, 2002 02:36 AM
